• Latest threads
    • Custom feed
      • Updates
        Old 25th October 2007, 23:18   #1 (permalink)
        omid
        omid's Avatar
        Oil Temp Concerns
        Hey Guys,
        Driving around town yesterday running errands, saw the oil temp swing past the halfway point (210 F) for the first time. It has been unusually hot and humid here...car indicated 99F, but probably more like mid 80's, the car was heat soaked getting turned off and on a couple times in a short period, but it still made me take notice considering how gently I was driving.
        I know I was no where near danger, and it did return to normal after a few moments, just got me thinking about what things would look like if I was driving hard. In my mind, any stock M car should be able to knock out laps at Willow Springs in the middle of summer with the AC on, with no issues. Is this wishful thinking? At what point should I be concerned, and for those who have tracked their cars on a hot day, what kind of temps did you see?
        Thanks,
        Omid
        02 Sterling Gray/Black M5
        Manhattan Beach, CA
        omid is offline
        Old 25th October 2007, 23:35   #2 (permalink)
        mottati
        mottati's Avatar
        you will find more data points with a search, but yes, my oil temp is a bit past 210F much of the time when the weather is nice or warm.
        Track with the ac on, you'll be on the side of the track after 2-3 laps. I rode with someone who kept his ac on at a track day once in the summer because it was hot, after a couple laps (if that) "bong" "engine temperature" coolant in the red, oil at 300.
        On a hot track day, without the ac, you will eventually have to back off or overheat. a few good laps, oil temp starts creeping up, coolant temp to follow. Only solution out there is the dinan oil cooler, but for the money (around $4k installed), i'll just short shift, back off, and let it cool down as needed.
        Engine:
        Suspension:
        Interior/Misc:
        mottati is offline
        Old 26th October 2007, 00:00   #3 (permalink)
        jclyman
        jclyman's Avatar
        Data point:
        Last year, I was driving in Nevada ... about 1:00 to 1:30 PM. Traveling over 100 MPH, long steady uphill stretch, A/C on, and the outside temp was 117 degrees. Really!
        Oil temp never got over 210 ... I was impressed.
        I find it usually goes higher when puttering around in traffic ... when out on the road, it rarely gets over 190.
        - Daniel Boorstin
        jclyman is offline
        Old 26th October 2007, 02:09   #4 (permalink)
        M5CCIE
        M5CCIE's Avatar
        What type of oil do you use?
        2003 M5 Sterling Gray
        Dinan 3.45 differential
        TMS Shark Injector - 91 Octane tune
        IATS Relocation - Inside Air box
        Strong Strut front brace
        TC Design rear swaybar brackets
        Bluetooth
        V1
        Aux port
        M5CCIE is offline
        Old 26th October 2007, 02:58   #5 (permalink)
        jclyman
        jclyman's Avatar
        My car is identical to yours ... same year and color ... I use the oil listed on the radiator shroud ... BMW Syn 5w-30. It's got 65,000 miles on it. Uses a quart every 4,000 miles.
        - Daniel Boorstin
        jclyman is offline
        Old 26th October 2007, 04:39   #6 (permalink)
        M5CCIE
        M5CCIE's Avatar
        Nice car!
        Bluetooth
        V1
        Aux port
        M5CCIE is offline
        Forum Jump
        Oil Change - Mityvac 7201 Review BimmerHead E39 M5 and E52 Z8 Discussion 2 8th January 2007 16:10
        Oil Temp too low? BBM5 E39 M5 and E52 Z8 Discussion 3 29th December 2006 01:21
        LE Back 'pon road & OIL Temp guage question illjah E34 M5 Discussion 10 22nd November 2006 19:31
        Engine Oil Leak Suspected - Non-Linear Oil Usage 507bhp E60 M5 and E61 M5 Touring Discussion 12 10th December 2005 22:05
        Page generated in 0.22339 seconds with 11 queries
