Old 22nd October 2007, 05:12   #1
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (3)
Outside temperature sensor?
Hey guys, a quick one here:
I'm still getting used to driving such a nice machine (and busy making a manual gearbox second nature), and there are always little things that I'm noticing with the car.
For example, I noticed that my car's computer thinks that it's -40 degrees outside. Any clues on how to fix this? I wouldnt care if it was another car, but this is an M5.....it's gotta be 100% functional!
Diny is offline
Old 22nd October 2007, 05:37   #2
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
Your temp sensor is probably unplugged or not working. Look under the front bumper, passenger side. I think -40 is the default reading when unplugged.
03 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C, Supersprint headers and Race cats, Dinan 17mm rear sway bar, TCD sway bar brackets
Eisenmann Sport Exhaust, Rogue UD Pulleys, Rogue SSK w/ RP Synchromax fluid, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, HID 6000K fogs, 70W High beams, Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
ECB is offline
Old 22nd October 2007, 08:59   #3
McLovin
Garage: E39 M5, Jet Black
mine reads +120F lately....tore my front right wheel well and managed to rip out a large chunk of plastic from the front right side of the car, nothing visible really, but still needs to be fixed....the Temp gauge is now hanging by wires.... naturally, i keep a roll of duct tape in my trunk. problem solved! ...for now.
McLovin is offline
Old 27th October 2007, 20:35   #4
Diny
Diny's Avatar
Sales Feedback: (3)
I looked and noticed that the whole thing is missing. Apparently, the guy who owned it before me ran over/into something and damaged the wheel well liner and the piece of plastic that covers the space between the wheel and the front of the bumper. There are 2 bare wires with nothing attached to them, so I'm guessing thats where the temperature sensor was.
Anyone have any ideas of where I can get the sensor? Thanks!
Diny is offline
Old 27th October 2007, 20:54   #5
azaytsev
azaytsev's Avatar
Garage: 2001 M5 Jet black/black
ebay, very cheap or dealer
azaytsev is offline
Old 28th October 2007, 02:56   #6
ard
ard's Avatar
It is really very cheap- $50 for the whole 'kit' at a dealer. Not sure ebay sells all the bits and bobs ... plus the dealer is easier to ensure you are getting what you need
You need the sensor, a connector shell and two pins (with wires pre-attached) to plug into the connector.
Splice the two wires onto the existing leads hanging down- solder, heat-shrink, each lead; then another heatshrink over both. Plug the two pins into the connector shell and you've repaired the wiring harness- then just mount the temp sensor into the new fender liner, connect the new connector to the back.
45 minute job
A
ard is offline
Old 28th October 2007, 03:31   #7
Diny
Diny's Avatar
Sales Feedback: (3)
Thanks a lot, Ard! Seems like I'm gonna have to jack the car and get to work on that, see if I can identify the proper connections, heh.
While we're talking about soldering, I figured I might as well get this one out of the way, too, even though it's not related to the sensor. I still didnt think it'd require its own thread.
Anyways, I was looking at the shifter and handbrake assemblies and noticed that on the shifter, there are 2 loose wires (with bare tips). I read on the manual that the shifter is supposed to light up when the lights are on, but mine doesn't. I figured that the loose wires are the culprit but I don't know where to connect them to get the shifter to light up again. Any clues?
Diny is offline
Old 28th October 2007, 04:00   #8
azaytsev
azaytsev's Avatar
http://www.realoem.com/bmw/showparts...=65&fg=70&hl=2
http://cgi.ebay.com/ebaymotors/BMW-A...spagenameZWD1V
azaytsev is offline
Old 28th October 2007, 04:17   #9
ard
ard's Avatar
Yes, the parts list you need #1 and the two pieces under #3 (two of the 'bushing contact')
I've never found an online source for the #3 pieces. But in all honesty I haven't looked that hard.
A
PS great board, eh?
ard is offline
Old 28th October 2007, 04:43   #10
Diny
Diny's Avatar
Sales Feedback: (3)
Originally Posted by ard View Post
PS great board, eh?
No kidding! What I love best is that there arent any snobs (or don't seem to be). I've been around the net for a while and boards like this are a breath of fresh air. Not to mention that everyone gives a ton of links to get stuff. Gotta love the internet!
PS not to be a ballbreaker but.....any ideas on how to fix the shifter?
Diny is offline
Knowledge base on Peake codes for E39 M5 kees E39 M5 and E52 Z8 Discussion 322 30th October 2009 02:51
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
Which temperature sensor does the ECU use? rigsby E39 M5 and E52 Z8 Discussion 4 23rd August 2006 01:21
Service Bulletin - 'Exhaust Gas Temperature Sensor' Úbermensch E39 M5 and E52 Z8 Discussion 3 30th November 2004 22:00
Oil temperature sensor M540i LE E34 M5 Discussion 2 31st July 2004 02:06
Page generated in 0.16743 seconds with 11 queries
