Old 4th October 2007, 03:42   #1
schmidtgr2
Garage: '98 540i
problem with e39 getrag 6 spd
My car has almost 100K miles. Tranny at times doesn't want to go into 3rd or later gears. It doeesn't grind, it simply feels like the gates are blocked. I have found that if I push the shift lever fully to the left as if I were preparing to shift into 1st, then let it go to it's normal detent position, and shift into 3rd, it slides into 3rd and subsequent gears with no trouble. I'm wondering how likely it is that I have an external (worn?) linkage problem vs. something internal??
schmidtgr2 is offline
Old 4th October 2007, 06:12   #2
Need4Spd
Need4Spd's Avatar
First thing I'd do is change the transmission fluid and bleed the clutch slave cylinder, and see if things improve if not be cured.
Need4Spd
Need4Spd is offline
Old 4th October 2007, 06:51   #3
HOVO
HOVO's Avatar
Garage: Titanium
sincros are wearing... I just tore into my tranny a few weeks back, have a bit over 90k miles on her. syncros didnt look very healthy, I also had a bit of a hard time sometimes changing into 2nd.
2002 Titanium M5.
HOVO is offline
Old 4th October 2007, 08:24   #4
Mike Krieger
Mike Krieger's Avatar
Garage: 2000 M5 Oxford Green
What's it like to get tranny parts? It seems like everyone replaces the tranny, but maybe that is just dealers. Mine has 105k and has a hard time going into 2nd and is not that smooth in the other gears. What do you think it would cost to get it rebuilt?
2000 Oxford Green/Extended Caramel
Split folding seats with ski bag
Alacantra headliner
Mk. IV nav upgrade v.27
16:9 monitor
UF Motorsport Intake air temp. sensor relocation
Bimmernav Bluetooth
PowerChip 93
OEM First Aid Kit
Hardwired V1
AA CAI
Bavarian Auto Angel Eye update
Supersprint headers, SS X-pipe and Evo Racing Cats
Dinan Stage 2 suspension
Dinan 3.45 Diff
Mike Krieger is offline
Old 4th October 2007, 17:42   #5
suprfknman
suprfknman's Avatar
Garage: 2001 BMW M5 BLACK
The selector mechanism and detents are worn out and the forks are bent. This is a common problem you can do a search there are many discussions on this issue. Unless you are a transmission guru and can tear it down and rebuild it yourself BMW sells a rebuilt trans to swap in.
Will
01 BLK/BLK
05 Toyota Sequoia (for the winter)
04 S55 AMG
05 S4 Cab
91 JZA70 twin turbo supra RHD
suprfknman is offline
Old 4th October 2007, 20:09   #6
Need4Spd
Need4Spd's Avatar
Getrag won't sell parts so you're stuck getting a replacement.
Need4Spd
Need4Spd is offline
Old 4th October 2007, 20:18   #7
Mike Krieger
Thanks, that is what I have heard, but I had hope that things were changing. I will save my pennies as I know I will need to replace it soon.
Alacantra headliner
16:9 monitor
Bimmernav Bluetooth
PowerChip 93
OEM First Aid Kit
Hardwired V1
AA CAI
Dinan 3.45 Diff
Old 8th October 2007, 07:28   #8
TeXJ
TeXJ's Avatar
Garage: 02 blk/blk
how much do the replacement trans usually go for?
TeXJ is offline
Old 8th October 2007, 09:01   #9
xr4tic
xr4tic's Avatar
Garage: 2001 Anthracite M5
you could always try shooting a PM to LSCMAN, from his posts, sounds like he's rebuilt a few of these transmissions, so he may be able to tell you more info.
John Baas
2001 Anthracite Metallic M5
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Old 8th October 2007, 13:15   #10
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Thru BMW, I think you are looking in the $6k range...
gsfent is offline
RS4 vs S6 vs M5 E39 driving experience (Long) vasbli E39 M5 and E52 Z8 Discussion 13 17th October 2006 19:16
Question about problem with O2 value M5 E39 fumaras E39 M5 and E52 Z8 Discussion 5 13th October 2005 10:53
big problem with my E39 M5 Josep E39 M5 and E52 Z8 Discussion 11 22nd June 2004 12:54
(Pics)BMW's Leading to Acquisition E39 M5 (Post Yours Here!) V-10 4 Me E39 M5 and E52 Z8 Discussion 5 13th May 2004 05:40
Dinan Exhaust AlbertM E39 M5 and E52 Z8 Discussion 5 6th October 2000 19:11
Page generated in 0.13246 seconds with 11 queries
