Old 4th November 2001, 06:22   #1
basil
basil's Avatar
Garage: Anthracite
Quick and inexpensive handling upgrade
As I was just having a romp around some tight curves I thought that some of you might like to dial out some of the understeer in the way that I've done it on my 540/6 which is to install a stiffer rear swaybar. I know this is so obvious but it seems we all talk about complete suspension upgrades and not such a simple and easy modification by itself. And inexpensive as well.
I've put my M5 suspension and brakes on my 540 (Dinanized the M). For a while I still used the stock 540 sport bars so when I got around to installing the M5 front and Dinan rear (full tight) bars the handling really changed for the better. I don't know how significant a change it will be moving straight from an M5 rear bar to a stiffer one but I would suspect that it would be worthwhile.
My driving style is such that I've ripped an aluminum rear sway bar bracket from each car so for me the stiffer rear bar makes sense. Btw, I use steel brackets now.
Just my two cents.
God, I miss my M
basil is offline
Old 4th November 2001, 08:58   #2
Bart Carter
Bart Carter's Avatar
Garage: 2002 M5 Bluewater/Caramel
basil,
Check "Handling Adjustments" in the Tricks and Tips forum.
-Bart
2002 Bluewater/caramel
Any other car is a compromise
Bart Carter is offline
Old 4th November 2001, 09:25   #3
basil
basil's Avatar
Garage: Anthracite
From your tips post: The absolute best way to
evaluate your suspension is using tire temperatures.
Bart, what is a good way to check the tire temperature? Also, how do I interpret the readings?
basil is offline
Old 4th November 2001, 09:33   #4
Bart Carter
basil,
You take tire temps with a pryometer. This is how any racer dials in his suspension. They are hand held and after a run you would take the temps across the tire and see if camber or tire pressures need to be adjusted.
I am trying to get enough time this weekend to put together info on just how to do this. Check back in tips and tricks Sunday night.
Old 4th November 2001, 09:45   #5
basil
basil's Avatar
Garage: Anthracite
Thanks Bart, I'm looking forward to your info.
basil is offline
Old 5th November 2001, 09:28   #6
Bart Carter
basil - done
basil, here you go.
I've posted what I consider is used by most racers. I know it has always worked for me.
You can find it under "Tuning with tire temperatures" on the Tips and Tricks Discussion. Combine this with "Handling Adjustments" and you will have a better understanding of what may work for your car.
Old 6th November 2001, 02:15   #7
basil
basil's Avatar
Garage: Anthracite
Bart,
Thanks for the effort and information. You add high value to the board. I'll print out your compilations and buy a pyrometer. This is certainly timely for me since I'm headed to Buttonwillow at the end of the month with my driving instructor.
I posted this on the tip forum but thought you'd likely see it here.
Basil
basil is offline
Page generated in 0.12292 seconds with 10 queries
