I get a strange rattle/pinging/creaking noise. Its definately outside the car and happens when accelerating from very slow speeds < 10mph and braking too.
Any idea's what this could be? Its actually quite loud, loud enough for pedestrians to hear it, and for it to echo back off cars and walls.
Sorry I can't give you an answer. I can only sympathise as I have the same problem.
My indie can't find anything wrong (other than he can hear it too).
I assume it will get worse, at which point we may discover the cause.
Mine certainly isn't front bushings as I replaced them all and it didn't cure the problem.
If/when I find out I will post the answer.
__________________ **** it, let's do it - Australian proverb
Small pieces of stone stucked at tires?
I have the sound sometimes.
It sounds bit like my winter tyres(studded).
So I guess it would be stones.
Thanks for the suggestion, but it is a metallic sound in my case. It isn't even a 'solid' sound like a 'clunk'. It's a weak metallic sound, hard to describe.
I checked my tyres just in case, but no stones.
If it is the same sound I am hearing then at least I am not the only one. Mine sounds like there is a marble stuck in the engine somewhere! It can't be related to rod knock because it does not only happen under load. It starts making this noise when the engine is good and warm and when I am just cruising (engine between 1500 and 2800 rpm). I also does NOT sound like the VANOS noise described here, but that does not mean that the VANOS is not the culprit. I have searched and SEARCHED through this board and others and have not been able to learn what this sound is or where it is coming from!
01 M5 Jet Black/ Imola
Borla Exhaust, UUC Lightened Flywheel/Performance Organic Clutch, UUC SSK/DSSR/Tranny mounts, AA CAI, Evosport Pulleys, H&R Front Springs, 9.5" M5 Wheels all around, VW MAF's/IAT Relocation..
I just had to have my rod bearings replaced, two were bad, and it did not make the noise only under load, you could hear it all of the time. It was quiet when the oil was cold, but after warm-up, you could hear it all of the time. It gets loader under load, but you can still hear it so I would be careful. Getting it fixed right away may save you from having to replace the rods.
2000 Oxford Green/Extended Caramel
Split folding seats with ski bag
Alacantra headliner
Mk. IV nav upgrade v.27
16:9 monitor
UF Motorsport Intake air temp. sensor relocation
Bimmernav Bluetooth
PowerChip 93
Royal Purple Synchromax
OEM First Aid Kit
Hardwired V1
AA CAI
Bavarian Auto Angel Eye update
Supersprint headers, SS X-pipe and Evo Racing Cats
Dinan Stage 2 suspension
Dinan 3.45 Diff
