Old 25th September 2007, 10:14   #1
cramer
cramer's Avatar
Garage: 01 M5 LeMans Blue
The latest projects: Thrust arm replacement, ext. detail and more
Been a busy couple weekends
Since a vibration started when braking I knew it was time for new thrust arms (58k on the car). After being jerked around by Vines Automotive (posting ebay auctions they didn't have parts for and then the parts were back ordered) I purchased a set from another seller. (similar auction can be found here: http://cgi.ebay.com/ebaymotors/BMW-E...3001QQtcZphoto )
The arms appear to be the same as Vines with the orange insert as seen below:
It's difficult to see in the pic (even more so when they were installed) but the stock bushing was split the length of the key way making it easily movable by hand. Install went smoothly on the passenger side, but the driver's side ball joint was stubborn and resulted in pulling the brakes so I could use my pickle fork. Also one tip: I found removing the sub frame sway bar brackets allowed the bar to move more so it was easier to fit the socket on the back thrust arm bolt.
Then came the brake ducts and re-routed air intake (was directly connected to the grill opening.
Then the damaged lower bumper covers/front wheel well covers were replaced with the corresponding ones with the brake cut outs.
The weekend before was detail day. Started with a wash and engine bay scrub then a full clay bar, 3 step polish and wax, all Griot's products. The result after a full day of work (better pics in the sun will come later )
Chris
cramer is offline
Old 25th September 2007, 14:00   #2
Ocean's M5
Ocean's M5's Avatar
Garage: 2002 M5
Thanks for the detailed pics for the install! I assume you have to have an allignment after completion...
You did really well with the detail also. It looks better than New.
2002-05 Build Carbon Black ///M5
First Aid Kit ~ Warning Triangle ~ Full BMW Tool Kit
Rear Cupholders ~ Stubby Air Stems ~ Rear Shades ~ PDC
M Audio ~ Fold-Down Rears ~ Black Sport Int.~ Yokohama Advan Sport~
Beast Power Sway Brackets ~ Tinting-80% Strip Windshield
Center Armrest *Storage Bin ~ ///M Black Trunk Mat
Ocean's M5 is offline
Old 25th September 2007, 19:10   #3
cramer
cramer's Avatar
No alignment is necessary since the thrust arms are not adjustable and swapping them out will not change the geometry of the suspension.
Chris
cramer is offline
Old 25th September 2007, 19:15   #4
Sebring NL
Sebring NL's Avatar
Need your wheels.
Need you garage floor
Very well done. Such a nice image. I have a thing for cars photographed in their place of sleep
Sebring NL is offline
Page generated in 0.10683 seconds with 10 queries
