Just curious if headers change the sound/tone of the car (louder/deeper/more throaty) with an aftermarket set?
For anyone that has done them with aftermarket exhausts or even on an otherwise stock exhaust system.
Thank you
Can only add one data point.
I added SS headers, no other changes. I did have Hamann cans.
At idle car is a little throatier, but not really noticable. At WOT there is a defintie increase in noise, but not objectionble. What i notice most is more bass, almost as if I added a subwoofer to the exhuast system.
If you are worried about noise from just headers (at least SS brand), don't be concerrned.
Once again, I am with Jerry on this one...what ever your sound "preference"...the headers and exhaust actually allow you to hear your shift points... instead of "feeling" them (by bouncing off the rev limiter)
The increase in cabin noise is minimal...
Mark
Super Sprint Headers (coated), X Pipe and mufflers
UUC V12 Power clutch and flywheel
Evo III SSK with DSSR and tranny mounts
Shadowman Velocity stacks and software
Shadowman rear differential with changed static and dynamic lock up, stock ratio
275's on front with a dinan rear bar and Beastpower brackets
Hard wired V1
Dual transponder Lidatek LE-30
Eurodash
Evosport Pulleys
Ground Control coil overs with adjustable camber plates
AA CAI, with AFE filters...the K&Ns ripped open
Relocated IATS
StopTech BBK on front, slotted rotors, with SS brake lines on all four corners
I think it is such a touchy subject, since some people will be more sensative to the sound, etc, and every car responds to mods differently. It is weird, but that's just how cars work, and I have seen it happen many times.
Anyways, if you are looking at some sort of aftermarket set up for your car, let me know, and I can try to hook you up on something. We carry a lot of various and diff brands of exhausts for your car.
