Old 21st September 2007, 16:01   #1
sdr
sdr's Avatar
Garage: Lemans Blue 2002 M5
Stiffer and Notchy Gearbox whilst car is cold
Hello All
I find my 2002 M5 has very notchy gearchange when cold.
It's nearing 29000 miles now, and until about 20 minutes into the journey, until everything has warmed up, the gearchange can be notchy and not slot into gear as easy as when warm. It will engage the gear if I apply more force, however I dont want to ram it into gear when cold too much
Does anyone else experence this? Is this a common problem?
CHRIS
sdr is offline
Old 21st September 2007, 16:27   #2
verhagke
verhagke's Avatar
Garage: 2000 BMW M5 (Titanium Silver)
very common. Some say that changing the tranny fluid will improve things
verhagke is offline
Old 21st September 2007, 16:33   #3
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Yes it is common - mine had it as well.
Many of us have made the problem considerably better by replacing the transmission fluid. Some like Redline, in my case I like Royal Purple. I also did my differential and it made a huge difference.
Doug
DouglasABaker is online now
Old 21st September 2007, 16:37   #4
xr4tic
xr4tic's Avatar
Garage: 2001 Anthracite M5
what weight is the trans fluid? how much fluid do you need?
I'll probably be doing the same thing before it starts getting colder here in MI
John Baas
2001 Anthracite Metallic M5
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Old 21st September 2007, 17:11   #5
DouglasABaker
Just about 2 quarts. Synchromax in the tranny, 75W140 in the differential.
Plugs get tightened to 50Nm. Make sure you remove the fill plug first. Don't want to drain it without the ability to fill it again...
Doug
Old 21st September 2007, 17:15   #6
chowdah
Garage: sweetness
Sales Feedback: (3)
On the off chance you are lugging around, get the rpms up, or blip the throttle -- that can help to find the sweet spot and change easier.
chowdah is offline
Old 21st September 2007, 17:31   #7
alijonny
alijonny's Avatar
Garage: 01 Titanium Silver M5
similar issue with mine going into 2nd. after it warms up, everything is good. this can also be caused by a worn/misadjusted clutch. how is the car driven?
alijonny is offline
Old 21st September 2007, 18:01   #8
sdr
sdr's Avatar
Thanks Guys, that'll put my mind at rest.
thanks chowdah, I do blip the throttle between changes, to try and keep the revs from dropping and climbing too much.
As for how the car is driven alijonny, I do baby it when it is cold. I've only had the car since May, and only done about 1000 miles. I dont slip or drag the clutch too much, however I've a feeling the previous owner did tho' and I also think that a new clutch wouldnt be a complete waist of money. It's just getting round to getting it done.
sdr is offline
Old 21st September 2007, 18:14   #9
Halston Pitman
Halston Pitman's Avatar
Garage: 1999 BMW M3 in AlpineWeiss
Definitely change out the fluids. BMW has the good old "lifetime fluid" in the trans. Don't trust that
While you are at it I would recommend dropping in some (Insert preferred brand of lube oil) into the diff since the car will be on the lift. Can kill two birds with one stone and do some maintenance!
Halston Pitman | BSW
Audio Solutions for YOUR BMW
e-mail: rhp@bavsound.com
phone: 404.963.8857
web: www.bavsound.com
Need immediate help?
AIM: HalstonBSW
http://www.bavsound.com/images/forumsig.gif
Halston Pitman is offline
Old 21st September 2007, 19:19   #10
DouglasABaker
I thought for certain you were going to tell him to drop in some new speakers
Which, btw, is not a bad idea!!
Doug
Notchy shifting as the car warms Usual Suspect E34 M5 Discussion 8 10th September 2007 03:29
Driving a Z8 vs. an M5... ME? TheM5Kid E39 M5 and E52 Z8 Discussion 10 29th May 2002 15:50
Your thoughts on the Z8 NO-MERCY E39 M5 and E52 Z8 Discussion 6 16th November 2001 06:26
OT: Z8 Roadster Millie Miglia E39 M5 and E52 Z8 Discussion 9 4th April 2001 01:25
Page generated in 0.14948 seconds with 11 queries
