• Latest threads
    • Custom feed
      • Updates
        Old 12th September 2007, 00:15   #1 (permalink)
        welsh_willo
        welsh_willo's Avatar
        Send a message via MSN to welsh_willo Send a message via Skype™ to welsh_willo
        memory circuit : steering wheel adjuster : re-wire req's
        ok .... #
        just replaced the fat boy comfort seating
        and fitted recaros sportlines
        thats means i have to re-wire the memory controller < where is it ? in the dash where the switches re seat heating : center console ? : this box sets the steering wheel location
        and is currently stuck up in the fully upright position < as you switch the ign off > so .... the loom for the comfort seats option create all sorts of problems here
        I want / need to find the wiring to create a fused feed into the switch on the column so that I can adjust the reach and height but not have this as a memory function
        any body done this or have the codes / loom diags ?
        any help here would be most appreciated
        ta
        Welsh _ Willo
        welsh_willo is offline
        Old 12th September 2007, 02:14   #2 (permalink)
        DouglasABaker
        DouglasABaker's Avatar
        I don't particularly understand your question - the memory seat controls are on your door. Are you looking for an additional set of controls over and above those?
        I'm totally lost with all the <, >, ?, : in your note - can you try to explain your thoughts more?
        More to the point: what is it that is stuck in the full upright position? The steering wheel?
        d-
        DouglasABaker is offline
        Old 12th September 2007, 02:29   #3 (permalink)
        welsh_willo
        memory position unit
        Doug
        i'm looking for the Seat memory controller storage unit
        its the actual memory unit < and its not in the door >
        with cars fitted with comfort seationg with massage units :
        the unit stores the locations : i.e you set them from the door
        those are just the switches which connect to the unit apparently
        I'm trying to locate the actual memory storage unit which the controls talk to so I can unfreeze / operate the steering wheel without memory
        by removing the comfort seats out and replacing them with recaros seat you effectively cease use of these and as you take out the seats the memory unit locks up
        the problem is the stored steering wheel positioning is stored in this unit : the s/wheel resets itself to max lift as u switch off the ign
        Its now stuck in the upright position and i need to have it operate manually
        agghhhh ... so where is the unit ?
        Welsh _ Willo
        Old 12th September 2007, 03:05   #4 (permalink)
        DouglasABaker
        Bored as I am, I decided to spend a few minutes on realoem.com.
        Unless I'm misreading it, the memory is built into the switches themselves (on the side of the seat, not the door)...
        http://www.realoem.com/bmw/showparts...15&hg=61&fg=35
        d-
        Old 12th September 2007, 04:24   #5 (permalink)
        LFC09
        LFC09's Avatar
        my understanding is that the switch unit and memory are together in the side of the seat, i think machtig (the member formerly known as reverend) has replaced the unit and may have posted details on it.
        2002 M5 Carbon Black
        Black/Grey leather
        Brushed Aluminium trim
        AiB 3.0 angel eyes
        AiB xenon match fogs
        BMW 545 shifter
        Dinan rear sway bar
        TCD rear sway bar brackets
        X5 4.8 thrust arm bushings
        Bimmernav Bluetooth upgrade
        phone cradle V3xx modified
        Solaris invisi-bulbs
        MkIV Nav V31 custom splash
        ex 1959 FC Holden sedan
        Last edited by LFC09; 12th September 2007 at 04:25. Reason: additional info re machtig
        LFC09 is offline
        Old 12th September 2007, 07:19   #6 (permalink)
        UberBeast
        UberBeast's Avatar
        Yeah the memory is stored in the module in the actual seat controls. I had the memory problem with the Steering Telescope not resetting properly when you armed and disarmed the car (if you tied the memory to the key FOB) and they had to replace the entire controlling unit in the seat to fix the problem.
        UberBeast is offline
        Old 12th September 2007, 07:39   #7 (permalink)
        mishkinm5
        mishkinm5's Avatar
        Did you have the sport seat with comfort? Any pics? I might be interested for a conversion here in the states.
        2006 BMW E60 M5
        ASR Ram Air intake
        Rogue Pulley
        RDSport Headers
        ASR 3" Exhaust
        16" front and 15" rear Brembos
        Neez QD7 20's
        RdSport Sways
        KW V3
        Dinan camber plates
        Dinan ball joints
        ASR Stage III Nitrous
        ASR Software
        Braille 21lb battery
        mishkinm5 is offline
        Old 12th September 2007, 10:59   #8 (permalink)
        welsh_willo
        Apparentlt no
        re memory unit in seat
        they are just switches !!
        its a control unit we nedd to locate
        I have BMW uk looking at tracing the part
        but as I have comfort seats with heat & massagers it not the same .. < AGGHH >
        BMW vines think its in the unit is in the dash for the heat / massagers
        keep the ideas coming though
        Welsh _ Willo
        Old 12th September 2007, 16:07   #9 (permalink)
        killcrap
        the switch on the seat is the Seat Memory Module, This module stores the hall sensor movements in the steering column and seat travel.
        killcrap is offline
        Old 12th September 2007, 22:45   #10 (permalink)
        welsh_willo
        making sense ...
        Kill
        Ok & arggh !!! : I think your'e right
        < Although BMW vines data techs's say its some where else on the comfort seat option & they haven't come back yet : I'll find out tomorrow when I call in the dealership >
        so I've just stripped the unit out of the comfort seat to have a look @ it
        found the feed wires in the block out for the column and will now trace them back to the floor harness plug numbering
        thinking about it : second option
        it maybe going to be esaier / simpler to wire a new live feed into the column housing directly to the adjuster column switch and just forget about the memory re-wire : the only thing which would be stored would be column positions anyway which is not that much of an issue
        the wheel is way to high with new seats in position
        i'll send some pics tomorrow
        thanks for the thoughts / help will keep you posted
        Welsh _ Willo
