power steering leak? - BMW M5 Forum and M6 Forums
post #1 of 12 Old 3rd September 2007, 01:05 PM Thread Starter
neuspeeder
neuspeeder's Avatar
I went into the dealership last weekend to pick up some oil, and while there (since I'm new to m5 ownership) I asked the guy @ service a question regarding an issue I began noticing. For about a week, every so often I would feel what felt like a buzzing feeling coming through the steering wheel when I made about 90 degree turns or greater. not always, but sometimes.
He suggested I just check to see if I was low on power steering fluid, so while at the dealership I did. to my surprise, the dipstick on the cap registered dry, and I could barely see a puddle of ATF fluid in the reserviour. He thinks I may have a small leak somewhere, so they were kind enough to top me off. I just checked again today, a little over a week later, and I'm still reading between the 2 hash marks, but the ATF fluid does seem to be a slight bit lower. Nonetheless, the buzzing feeling has yet to return.
is this a chronic problem? anyone else experience this? solutions? I have an aftermarket extended warranty, but the dealership is about 2-3 wks out booked, and I'm just wondering if this is really something worth worrying about.
any insight is much appreciated.
neuspeeder is offline
post #2 of 12 Old 3rd September 2007, 03:22 PM
CSBM5
CSBM5's Avatar
Power steering hose leaks on the M5 are common. I had mine all replaced at about 35k miles (43k miles on my car now) when one developed a slight leak. You should be able to see if there is a significant leak or not. Check out the realoem diagram and then inspect the car.
Current stable:
Dinan: springs, Konis, rear sway bar, monoball bushings;
Ground Control camber plates, Brake ducts opened, Evolve tune,
OE 9.5" rear wheels all around & 275/35-18 Pilot Super Sport
2011.5 M3 sedan 6MT Silverstone, slicktop
Dinan front swaybar, Eibach rear swaybar, pins-out-max-camber-up-front, BFG Rivals autox/Michelin PSS street/Nitto NT-01 time trials
2007 328i wagon Silver/gray
2006 330i E90 ZSP 6MT Electric Red/Black
1975 CanAm 125MX2
CSBM5 is offline
post #3 of 12 Old 3rd September 2007, 08:23 PM
Laidback
Not to worry just make sure you check the reservoir at all times and top it off...there are two hose for the power steering one is cheap and the other ones is expensive...labor would be around 2-4 hours depending which hose is affected...
"Illegitimus non carborundum"
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Laidback is offline
post #4 of 12 Old 3rd September 2007, 10:23 PM Thread Starter
neuspeeder
neuspeeder's Avatar
thanks for helpful insight, I'll see if I can visually locate any leaks, and grin & bear a bit longer, at least until the dealer's appt's aren't so booked up.
post #5 of 12 Old 3rd September 2007, 10:34 PM
SeattleM5
SeattleM5's Avatar
I've dealt with this problem as have many other e39 owners. Had one leak fixed by dealer under warranty, the other I fixed all while the car still had <30k mi. My repair was quite simple but the complexity depends on where the leak is originating from. From my research most leaks originate from where the hoses meet the power steering fluid reservoir (BMW's one time use hose clamps are prone to failure). I did a little write up a short time ago (see post#6 & 8): Change Power Steering Fluid? Hope this helps.
SeattleM5 is offline
post #6 of 12 Old 3rd September 2007, 10:57 PM Thread Starter
neuspeeder
neuspeeder's Avatar
thanks, yea my car only has 34K on it, so I also thought it odd that something like this would happen so soon......I'll check out the suggested problematic area.
post #7 of 12 Old 3rd September 2007, 11:48 PM
Vason
Vason's Avatar
I had that same buzzing feeling and sound when taking hard turns either way. Power steering hose was the problem and was replaced. My car had 41k miles at the time.
'16 M3 Alpine White/Black
'03 M5 Carbon Black/Caramel - Sold
'03 M3 Alpine White/Black - Flooded/R.I.P.
Vason is offline
post #8 of 12 Old 4th September 2007, 06:15 AM Thread Starter
neuspeeder
neuspeeder's Avatar
post #9 of 12 Old 4th September 2007, 08:07 PM
TopEnd
TopEnd's Avatar
TopEnd is offline
post #10 of 12 Old 25th September 2007, 01:56 PM
Gustav
Administrator
Gustav's Avatar
Doesnt it also leak fro mthe reservoir itself? When I engage hard truns at speed I loose power steering
Gustav is offline
BMWNA pressrelease on 6-speed manual M5 kees E60 M5 and E61 M5 Touring Discussion 10 9th February 2008 07:50 AM
Power steering problem Cyrus E34 M5 Discussion 10 25th December 2006 05:13 PM
leaking power steering fluid Mike Krieger E39 M5 and E52 Z8 Discussion 2 19th November 2006 04:42 AM
Leaky Power Steering Reservoir Question SWP E60 M5 and E61 M5 Touring Discussion 7 23rd May 2006 04:37 PM
POTENTIAL OWNER-CHICAGO VROOM5 E39 M5 and E52 Z8 Discussion 15 17th November 2004 05:15 AM
