3.62 Diff Gear Upgrade using E46 M3 Ring and Pinion
Hey guys new owner here!
I plan on changing my OEM 3.15 gears to 3.62 using the direct swap of OEM E46 M3 ring and pinion. My mechanic confirmed this can be accomplished and while the work is performed the seals and certain internal components will be swapped such as the seals, crushed sleeves, bearing and shims.
Used ring and pinion costs $200 and labor is about 8 hours. Total estimate of about $1000.
Has anyone else performed the swap instead of buying Dinan's $2500 differential?
This is the first I've heard of this mod, but perhaps the question should be "why"? 3.62 seems like awfully short gearing for a V8 that is more rev limited than the M3 engine's 8000 rpm redline, and has far more torque. Aren't you worried about making 1st gear almost uselessly too short, and actually making your 0-60 times longer by needing an extra shift? I'm not saying this is necessarily a bad idea, but the Dinan gear set is 3:45 and perhaps so for a reason. The M5 isn't really suited for drag racing, which is often the reason for going to very short gears.
Need4Spd
First off I would NEVER use a USED set of gears. I know of somebody who has the 3:62's and they are some very short gears. He has been questioning going down to the 3:45's.
Several people have opted for the Dinan or Evosport 3.91 gears and reported increase in noise. I feel that these are too short and 3.62 is perfect according to Evosport's 3.64 kit. My mechanic said used gears are fine as they will somehow be repolished in the installation process.
"Give your E39 M5 the additional torque it needs with our upgraded 3.64 or available custom gearing (call). The new 3.64 gears alone add almost 10% additional torque to the rear wheels. With a negligible loss in top speed and engine speed, the upgrade delivers awesome and instant acceleration and exit speeds making this the "best-bang-for-the-buck" upgrade for this car."
he 3.91m5 gearset is for the e60. I have the 345s and they are totally fine day to day. 364s might be a little short, but that's cheap enough to experiment.
my e34 has 391s (oe) and that too is really ok on the highway.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
I have been thinking of this too...I'd like tp get some snap put back in the car... I am a mile high elevation.
I can't find a shop that'll do it. I wonder if I can do it myself...I am very mechanically inclined...diffs are one if the only things i haven't done.
Garage: 2000 Alpine White M5 FOR SALE 7/00 build revised rings
PM for more details
Hers: 03 oxford green X5 3.0
DD: 2005 Honda Civc..37.5MPG!!!
............I plan on changing my OEM 3.15 gears to 3.62 using the direct swap of OEM E46 M3 ring and pinion.....
Why?
The first gear ratio is already too deep for full throttle launch with street rubber. Deeper gears will only aggravate the issue. Acceleration will not improve unless you install slicks and that will quickly tear out your flimsy aluminum subframe. Who needs or wants a creeper gear in an M5 to improve torque multiplication at walking speed? I think another overdrive is more useful.
That may be, but make sure you compare the gear ratios of the transmissions, too. The car that comes stock with shorter rear end gears may have a taller final gear in the transmission. Also, cruising along the highway at 3200-3400 rpm with a 6 cyl engine qualitatively may feel more comfortable than doing that with a torquey, more rumbly V8.
To restore torque at higher elevations, gears help, and are less money than a turbo or supercharger, but have their drawbacks in really shortening your first gear if overdone. If I lived in a high elevation area, much as I like my M5, I'd be tempted to switch to a turbocharged car, either a current 335i or one of the Audi turbos.
Need4Spd
will you ask your mechanic where he is getting the crush parts, seals, etc. I will be doing this myself. I just need some direction on where to get the parts.
PM for more details
