m5board.com Advertisers are: Download GTBoard.com Supercar Shootout 1 + 2 in HD 1920x1080 360 Forged 503 Motoring (OR) Angel iBright ASR Engineering Bavarian Soundwerks Bimmer Performance Store BMS BMW service CA Automotive CNS RacingDinan Cars EisenmannNA ESS Tuning Eurosport Design Evosport GTboard.com < "Supercar Shooutout II: 40+ car in action incl. BMW M3 E92" Hartge (Member discount) HRE Wheels Kreissieg Medford Tools (OR) Meist GT modbargains.com Neez Powerchip Group Race Precision Revozport Supreme Power (CA) TireRack BMW M5 Upgrade Garage for wheels, tyres and suspension Tubi Style North America Turner Motorsport Umnitza UUC Motorwerks Zeckhausen Racing BLACK LIST OF NON-APPROPRIATE VENDORS Be an m5board.com Advertiser!
Old 20th August 2007, 00:53   #1 (permalink)
J Irwan
J Irwan's Avatar
View my 02 CB M5
PSS finally installed.
Finally I had a chance to put my PSS9 on my car this weekend.
ITs about time, after been sitting there for few weeks
Here is the pic
Measuring at 13-7/8" on the front and 13-3/8" on the back.
The PSS9 is set at 6 (front) and 6 (rear).
Regardz,
J Irwan
02 Carbon Black ///M5
J Irwan is online now
Old 20th August 2007, 00:54   #2 (permalink)
J Irwan
J Irwan's Avatar
View my 02 CB M5
This is a comparison of old shock and rear
Pic1
See how short PSS9 rear shock vs OEM
Pic2
See how short PSS9 front shock vs OEM
pss-finally-installed-img_3087_resized.jpg  pss-finally-installed-img_3094_resized.jpg
Old 20th August 2007, 00:59   #3 (permalink)
J Irwan
J Irwan's Avatar
View my 02 CB M5
Here is more pic
Pic 3
PSS9 Front shock adjusment, easy access with just jacking the car up. (No need to take the wheel off).
Pic 4
I measure that the tender/helper spring already compressed at 15" (center wheel bore to fender distance).
So at static height around 14" the little spring definitely will already be fully compressed.
pss-finally-installed-fronts-bottom-adjustment.jpg  pss-finally-installed-img_3096_resized.jpg
Old 20th August 2007, 01:07   #4 (permalink)
Jayson
Jayson's Avatar
View my m5
Send a message via AIM to Jayson
Nice house.
Jayson is offline
Old 20th August 2007, 01:10   #5 (permalink)
J Irwan
J Irwan's Avatar
View my 02 CB M5
Initial impression when driving the car (test drive after fitting in the suspension),
Deceleration(Braking)
what I noticed the most is the "nose dip" during braking is virtually eliminated,
Acceleration
and the "squad" during acceleration is greatly reduced.
Cornering
Cornering is definitely flatter. It aspired more confident in the same turn with the same speed. I'll be fimilarizing myself with the new suspension for the next couple of day ).
Ride
The ride doesn't differ much from the stock ride. Some bump feels firmer than the OEM, but some bump actually feels better compare to OEM setup
Suspension weight difference
I didn't weight them in scale, but just by holding them OEM strut shock weigh t the same as PSS9.
In the past I've always had suspension modification to be the first thing on my car.
With the beast I wanted to enjoy the factory setup and all the hard work ///M Team put in this car.
But after having PSS9 installed, now I know what I have been missing.
This car should came like this from the factory.
If any of you think M5 stock suspension handle great, you don't know what you're missing out .
Regardz,
J Irwan
The Following User Says Thank You to J Irwan For This Useful Post:
iconoclast (6th April 2008)
Old 20th August 2007, 01:26   #6 (permalink)
drallen
drallen's Avatar
View my M5 Jet Black
Acceleration
Cornering
Ride
Regardz,
J Irwan
Nice set up....if you really want to get rid of the "push" and drive on rails...go for the stock 9.5" up front...
Mark
Super Sprint Headers (coated), X Pipe and mufflers
UUC V12 Power clutch and flywheel
Evo III SSK with DSSR and tranny mounts
Shadowman Velocity stacks and software
Shadowman rear differential with changed static and dynamic lock up, stock ratio
275's on front with a dinan rear bar and Beastpower brackets
Hard wired V1
Dual transponder Lidatek LE-30
Eurodash
Evosport Pulleys
Ground Control coil overs with adjustable camber plates
AA CAI, with AFE filters...the K&Ns ripped open
Relocated IATS
StopTech BBK on front, slotted rotors, with SS brake lines on all four corners
Jet Black 2002 M5
drallen is offline
Old 20th August 2007, 03:15   #7 (permalink)
Hawkwind
Hawkwind's Avatar
Nice job. Do you know what the front camber is with your new set up?
Hawkwind is offline
Old 20th August 2007, 04:41   #8 (permalink)
J Irwan
J Irwan's Avatar
View my 02 CB M5
Originally Posted by Jayson View Post
Nice house.
Thanks for the kind word.
Mark
I'll probably do that someday. But for now, I'll just enjoy this new upgrade
Not yet,
But I will have it align after the suspension settled.
I'll let you know then.
BTW does anyone has the factory alignment spec for our beast ?
Regardz,
J Irwan
Old 20th August 2007, 08:17   #9 (permalink)
MGZ
MGZ's Avatar
View my M5 e39 Carbon Black
Sales Feedback: (3)
Nice. Same setting as I have on my Billsteins I do however think that the ride is a little harsher than normal. Maybe because of 19" wheels. Cornering, braking etc. is very much improved.
MGZ is offline
Old 20th August 2007, 13:03   #10 (permalink)
palantirion
Company Representative for BMS
palantirion's Avatar
+1, + camber plates!
www.ebsart.com
2007 Z4 M Coupe, Titanium Silver with Imola Red, black and silver interior
-for details: www.mymcoupe.com
2003 M5, Imola Red with black and silver interior
-Dinan S2 drivetrain
-Dinan stage 3 suspension with JRZ shocks
-StopTech brakes
-Rogue Engineering short shift kit and clutch stop
-275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
-Progressive window tint
-Euro dash and armrest conversions
-CDT/Total audio, NavTv w/ DVD
-Seat massagers
2002 540iT, Sapphire Black with black and red interior
-Dinan stage 3 suspension with Koni shocks
-StopTech brakes
-255/40R18 PS2s f/r on 18x8.5 BBS RG-Rs
-Custom interior trim and seat massagers
-NavTv with DVD
Performance mods by: BMS
palantirion is offline
Old 20th August 2007, 22:49   #11 (permalink)
Beamer_usa
Beamer_usa's Avatar
View my explosive ford pinto
2000 Silvr(354)/Blk(M1SW)
Dinan Cans
PC 93
Beamer_usa is offline
Old 20th August 2007, 23:13   #12 (permalink)
GST
GST's Avatar
View my '03 LMB
Looks great! How long did it take you to install all 4?
Glen Tokuhara
A few cars.
GST is offline
