m5board.com Advertisers are: Download GTBoard.com Supercar Shootout 1 + 2 in HD 1920x1080 360 Forged 503 Motoring (OR) Angel iBright ASR Engineering Bavarian Soundwerks Bimmer Performance Store BMS BMW service CA Automotive CNS RacingDinan Cars EisenmannNA ESS Tuning Eurosport Design Evosport GTboard.com < "Supercar Shooutout II: 40+ car in action incl. BMW M3 E92" Hartge (Member discount) HRE Wheels Kreissieg Medford Tools (OR) Meist GT modbargains.com Neez Powerchip Group Race Precision Revozport Supreme Power (CA) TireRack BMW M5 Upgrade Garage for wheels, tyres and suspension Tubi Style North America Turner Motorsport Umnitza UUC Motorwerks Zeckhausen Racing BLACK LIST OF NON-APPROPRIATE VENDORS Be an m5board.com Advertiser!
Old 19th August 2007, 18:18   #1 (permalink)
BlaqueM5
BlaqueM5's Avatar
View my 2001 M5 Jet Black
Help!! OBD code P1634, Throttle Valve Adaptation; Spring Test Failed
I've been getting this code off and on for the past couple of days. Also sometimes when I start, the car goes into "ENGINE FAILSAFE MODE" and won't rev until I turn it off and restart. Anyone have any ideas what may need to be replaced? I have search the forum and couldn't find any issues related to this particular code. P1634 Thanks in advance
Robert
2001 Jet Black M5
-TMS SHARK INJECTOR
-B&B TRIFLOW EXHAUST
-SUPERSPRINT X PIPE
2003 Mercedes C230K
BlaqueM5 is offline
Old 19th August 2007, 19:47   #2 (permalink)
Need4Spd
Need4Spd's Avatar
The throttle valves (one for each cylinder) are actuated by electric servos. From the code description, sounds like one or more valves or their sensors have failed. This will likely require a visit to a professional tech.
Need4Spd
Need4Spd is offline
Old 20th August 2007, 21:30   #3 (permalink)
BlaqueM5
BlaqueM5's Avatar
Thanks. Its at the dealer right now. Also I got another code. P1637.
BlaqueM5 is offline
Old 12th April 2008, 02:36   #4 (permalink)
EVO3M3
What fixed the P1634 code?
Hello,
I have a 2001 M5 that is giving me the same codes and error message. Could you tell me what the dealer had to do to fix the problem??
Thank you!
EVO3M3 is offline
Old 12th April 2008, 17:53   #5 (permalink)
alijonny
alijonny's Avatar
very OT: has anyone ever attempted to install carburetors on the s62 like some downdraft webers? that would look cool... but function is another issue!
alijonny is offline
Old 12th April 2008, 20:19   #6 (permalink)
Need4Spd
Need4Spd's Avatar
Uh, I can't imagine why anyone would want to do that. There would be no increase in HP, and likely a decrease, together with poorer driveability generally, and especially when cold. I suppose it would look cool, though, especially with that big dome or cutout in the hood that would require to clear them.
Need4Spd is offline
Old 12th April 2008, 22:10   #7 (permalink)
EVO3M3
Code P1634
Hello,
Thanks for the information on the headers however I was wondering if you know what the other gentelman had to do to correct the issue's he was having from the OBD II code P1634?
EVO3M3 is offline
Old 13th April 2008, 00:54   #8 (permalink)
BlaqueM5
BlaqueM5's Avatar
Originally Posted by EVO3M3 View Post
Hello,
Thank you!
Hi. The dealer replaced the throttle actuator. You can see it here. It is item 1. http://www.realoem.com/bmw/showparts...=12&fg=10&hl=2 They also reset the adaption values. Good as new!
BlaqueM5 is offline
Old 13th April 2008, 01:57   #9 (permalink)
EVO3M3
P1634
Thank you for the information do you know what they had to do to reset the other valves? Was it just as simple as clearing the codes and done? (I wish!) BUt is doesn't hurt to ask!
EVO3M3 is offline
Old 13th April 2008, 03:41   #10 (permalink)
BlaqueM5
BlaqueM5's Avatar
I have cleared the codes but, It will keep coming back. At the time my car had 76,323 miles on it.
This is what I have on my receipt:
Customer states there is an Engine failsafe program light on.
Throttle motor faulty.
Interogated fault memory, submitted puma case #12166816, per puma case replaced throttle motor. Also checked throttle body syncronization, throttle bodies syncronized correctly, no adjustment needed. Cleared fault memory, reset adaption values.
Parts 12-72-7-831-246 Throttle actuator
Hope this helps.
BlaqueM5 is offline
Forum Jump
Knowledge base on Peake codes for E39 M5 kees E39 M5 and E52 Z8 Discussion 208 2nd September 2008 11:23
Autocar: M5 beats Ferrari F430 Just_me E60 M5 and E61 M5 Touring Discussion 204 10th October 2007 16:24
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 15:43
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
An in-depth SMG II review (LONG) kenneth E39 M5 and E52 Z8 Discussion 17 10th March 2004 00:31
