m5board.com Advertisers are: Download GTBoard.com Supercar Shootout 1 + 2 in HD 1920x1080 360 Forged 503 Motoring (OR) Angel iBright ASR Engineering Bavarian Soundwerks Bimmer Performance Store BMS BMW service CA Automotive CNS RacingDinan Cars EisenmannNA ESS Tuning Eurosport Design Evosport GTboard.com < "Supercar Shooutout II: 40+ car in action incl. BMW M3 E92" Hartge (Member discount) HRE Wheels Kreissieg Medford Tools (OR) Meist GT modbargains.com Neez Powerchip Group Race Precision Revozport Supreme Power (CA) TireRack BMW M5 Upgrade Garage for wheels, tyres and suspension Tubi Style North America Turner Motorsport Umnitza UUC Motorwerks Zeckhausen Racing BLACK LIST OF NON-APPROPRIATE VENDORS Be an m5board.com Advertiser!
Old 16th August 2007, 23:19   #1 (permalink)
Turbo M3
View my Turbo M3 / 1,000 hp
Maximum naturally aspirated power for S62
Maximum power, NATURALLY ASPIRATED, for S62
I have been in love with S62 and was wondering how much power it could produce, in naturally aspirated trim.
On my dyno dynamics, S62 made 292 whp, bone stock. Please don’t argue about the base power, this changes from dyno to dyno. The logic which I am pointing is different and as follows:
Then we changed the pistons with 12.0:1 compression J.E
Con rods were stock.
Cylinder head ported
Crankshaft balanced for the new light weight pistons
Schrick 268 degree camshafts, 1 mm intake and exhaust valves for some better breating11,3 mm lift
Cold air intake kit/ a copy of AA, which we use, it is not a very cold intake, better than OEM. But a wilder intake system (below this page) can add more air.
Removal of cat converters
Supersprint mufflers
Removal of resonators.
I have tuned the OEM ECU, where the air fuel ratios are set to 12,8:1 and ignition maps are optimized.
Vanos maps are re-programmed
Result power is now 353 whp. This is an increase of 61 whp from stock, which is equal to 87 flywheel horsepower.
This is not the maximum power we can get out of the S62. What can be done more?
Schrick`s 268 cams are not that good, this is my own opinion. Why cause the peak power with the Schrick cams come at around 200 rpm over standard peak power. This meant we limit the max engine speed at the original 7000 rpm. There is simply no need to rev over 7000 rpm as the power stops increasing after 6800 rpm.
Now to make more power,
To make more naturally aspirated, custom made cams, with for example 284 degree would add more power. Thus the peak power will be made 7200-7500 rpm.
Add to this a DRY SUMP OIL SYSTEM.
Add to this an ELECTRIC FAN.
Cutting holes into the hood, and directing air from these hoods into the intake manifold, sounds mean, but this will be the least restrictive intake.
The software should be dyno tuned with great care and detail.
With the wilder cams, dry sump and electric fan there will be more Naturally Aspirated Power. Over 353 whp, how much I don’t know, but more than 353 whp.
I have not tested the latter set up, but some brave-hearted M5 owners can test. I was stuck was 353 whp, maybe Schrick can custom make 284 cams and a dry sump is system where you need to have experience, I have no dry sump experience.
Mert
Twin Turbo E46 M3 & E36 M3
Turbo M3 is offline
Old 16th August 2007, 23:23   #2 (permalink)
ModBargains
Company Representative for ModBargains
ModBargains's Avatar
Send a message via AIM to ModBargains
So you just raised your compression ratios?
Visit Our Site! www.modbargains.com E-mail: roger@modbargains.com Phone: (714) 582-3330
AIM: modbargainroger
ModBargains is offline
Old 16th August 2007, 23:24   #3 (permalink)
Turbo M3
Oh yes, here we can fill with 100 octane Shell V-Power, a litre costs 2,5 USD. One full tank costs 150 USD.
I love high Compression Ratios.
Turbo M3 is offline
Old 16th August 2007, 23:44   #4 (permalink)
wilsodh
wilsodh's Avatar
What's not to like about forced induction??
The best I've heard of is Martin Christensen's NA S62 (All German Auto). It has intake, cams, throttle bodies, air stacks, larger injectors from Dinan and custom headers. Crank hp is 553 @7200 Rpm. All internals are 100% stock. I don't know what dyno he used. This engine is in his Baja off-road racing buggy. I wish I had more details, but that's all I know about it. I have an inquiry to him on whether this configuration could be applied to street cars for those who are not concerned about passing emissions inspections. Here's a pix I snapped during a brief visit before I had to rush off to the airport.
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
Old 16th August 2007, 23:47   #5 (permalink)
ModBargains
For some reason, this one thread, the html or the format seems to be all over the place.
Old 17th August 2007, 00:02   #6 (permalink)
drallen
drallen's Avatar
View my M5 Jet Black
And I thought that it was just my browser....because it is still a couple hours to happy hour....
Mark
Super Sprint Headers (coated), X Pipe and mufflers
UUC V12 Power clutch and flywheel
Evo III SSK with DSSR and tranny mounts
Shadowman Velocity stacks and software
Shadowman rear differential with changed static and dynamic lock up, stock ratio
275's on front with a dinan rear bar and Beastpower brackets
Hard wired V1
Dual transponder Lidatek LE-30
Eurodash
Evosport Pulleys
Ground Control coil overs with adjustable camber plates
AA CAI, with AFE filters...the K&Ns ripped open
Relocated IATS
StopTech BBK on front, slotted rotors, with SS brake lines on all four corners
Jet Black 2002 M5
drallen is offline
Old 17th August 2007, 00:24   #7 (permalink)
gsfent
gsfent's Avatar
View my 01 M5 Black/caramel
Good outcome, but at what cost? If just a theoretical exercise, good information. But in the real world, expense is a big factor. Opening the motor, adding pistons, changing cams and even porting the heads needs someone with a fair degree of skill so it is done correctly and put back together without any leftover pieces!!
Care to share the cost of parts and the number of hours of labor that went into 87 crank horsepower?
Dinan Stage3 suspension and CAI, SS jet coated headers, Evosport UD pulley kit, IATS, PC Gold 93, open brake ducts, Hamann front splitters, TEC cupholder, Euro tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, 2.65 diff w/40% lockup/2x dynamic, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit
gsfent is online now
Old 17th August 2007, 00:32   #8 (permalink)
drallen
drallen's Avatar
Jerry,
As I understand the thread, he got 353 RWHP from the motor. You and I run about 360 RWHP with our header set ups...so I hope that there would be more gains with porting, cams and 1+mm valves...
Mark
drallen is offline
Old 17th August 2007, 00:36   #9 (permalink)
MCarRacr07
MCarRacr07's Avatar
Originally Posted by drallen View Post
Jerry,
Mark
+1...what about the Dinan S2 set-up....NA motor mostly stock internals..470 crank hp right???..cams & rods should give you a bit more.
MCarRacr
89 M3 (Track Car) SOLD
00 M5 (R.I.P)
00 540 Sport (Gone)
03 330xi (Gone)
06 330xi (Son's Car Now)
08 328xi(New Arrival)
95 M3 (Track Car)
08 M3 (lil Beast)
MCarRacr07 is offline
Old 17th August 2007, 02:23   #10 (permalink)
gra8fuldd ed
gra8fuldd ed's Avatar
Did I miss something OR did Mert's S62 NOT have any Headers. Yes he has NO Resonator and SS Cans ... But No Headers .&. NO Larger Throttle Bodies and matching Software should be good for about 20 to 30 More HP.
gra8fuldd ed is offline
