My wife calls me this morning and tells me that all of the 5 series cars are at the bottom of the list when it comes to being safe , and went on to say that they (The Today show) were comparing our cars to Kias , anybody else catch this?
Anders
'02 BMW M5 (Carbon black / black leather)
Stock apart from Eisenmann Sport, E60 545 short shifter mod, MKIV nav and Intravee II
'95 BMW 320i Touring (black / black cloth)
ex '01 BMW 530D Touring (Sterling grey / beige leather)
ex '98 Mercedes C43 T AMG (Smaragd schwarz / black leather)
ex '99 BMW M Coupé (Cosmos black/ black-kyalami leather)
ex '93 Alfa Romeo 164 24V Super (Silver / black leather)
Not our E39 which is rated highly for crash worthiness...
Mark
Super Sprint Headers (coated), X Pipe and mufflers
UUC V12 Power clutch and flywheel
Evo III SSK with DSSR and tranny mounts
Shadowman Velocity stacks and software
Shadowman rear differential with changed static and dynamic lock up, stock ratio
275's on front with a dinan rear bar and Beastpower brackets
Hard wired V1
Dual transponder Lidatek LE-30
Eurodash
Evosport Pulleys
Ground Control coil overs with adjustable camber plates
AA CAI, with AFE filters...the K&Ns ripped open
Relocated IATS
StopTech BBK on front, slotted rotors, with SS brake lines on all four corners
You plannin' on having an accident?
Actually, it was the 2008 5 series (a redesign, according to the article on the Internet), as drallen pointed out ... our cars are rated highly.
If you want to be safe drive a Greyhound bus ...
THanks guys for the correction , i will be sure to show her this thread, i had to bring it up , that was one of the selling points that i used when picking this car up for HER!!
I heard that a lot of car manufacturers build their cars to do well in crash tests, the likes of Renault pay particular car to the NCAP testing. BMW and other more prestigious marquees like Mercedes build their cars to withstand crashes at might higher speeds and because of that do not do as well in the lower speed tests due to the stiffer nature of the cars.
I for one rather have a car safer at high speeds than low.
__________________ BMW E46 M3 SMG Carbon Black/Cinnamon BMW E39 M5 Avus Blue - SOLD
A couple of comments. First, often times popular press confuses crashworthiness with safety, and considering the former, it often comes down to how much it costs to fix a car involved in a relatively low speed 5-10mph crash. BMWs don't do well in that comparison b/c parts and labor are so expensive.
When considering safety, the "star" ratings only compare cars in the same relative classes, and it's based on weight. So if a subcompact Kia has 5 star rating, for example, it means it comes out on top as compare to other subcompacts in the same weight class. That is almost meaningless in a collision between a Kia and a large SUV, though in theory the Kia would do better in that confrontation as compared to another subcompact with fewer stars to its rating.
Finally, as you can see, different designs can garner different results. The e39 did much better as compared to its 4000 lb. weight/size class competition than the newer e60, but again, we don't know what the criteria were. Even then, apples to apples, you have to be sure the tests included offset impacts. Often certain cars will do well in straight-on barrier tests but in the more common offset collisions in the real world (like when the car in the opposite lane hits a car left fender to left fender), people might get killed or seriously injured. Such collisions expose chassis weaknesses more readily than square impacts.
All of this being equal, I'd still rather be in my e39 than an e60!
Need4Spd
