Old 10th August 2007, 05:09   #1
CWY_M5
CWY_M5's Avatar
Garage: '00 M5 Silver; '91 M5 white; '01 525iT white; '94 525ia Black
Is there L / R on Control Arm? I think I got 2 Rights. Okay to use?
So I received the control arms from Vines, still waiting for my Thrust arms from Vines.
I open up the box, to see two IDENTICAL control arms.
The stock arms has the bumps, channel grove where height sensor goes in, and stickers on "opposite" ends.
The vines I got are identical. I suspect they will fit, but the bump and channel groove will be facing front for the right side, and facing rear for the left side. Anything else won't work??
Chino
CWY_M5
E39 M5
'00 Titan Silver
99k miles
Koni FSD with Stock Springs and Vines arms
Intravee iPOD adapter
Clear Headlight w/ angel eye (CCFL)
Rear CELIS LED lights
BlueTooth Retrofit (LOVE THIS)
V1 direct wire w/ Blinder Extreme M20
MK-IV DVD Nav upgrade w/ 16x9 wide screen monitor
M-Sports Steering Wheel upgrade
E34 M5 '91 White (Newly acquired)
110k miles
Bone Stock - make your suggestions!!!
Other BMWs:
E34 525ia '94 Black (189k mi)
- Power chipped
- Bluetooth (Motorola)
- V1 direct wiring
- HID projector headlight
- Updated suspension (DIY)
E39 525iTa '01 White (68k mi)
- V1 direct wiring
CWY_M5 is offline
Old 10th August 2007, 06:29   #2
M540i
M540i's Avatar
Garage: 2001 540i, Jet Black
Send a message via AIM to M540i
If you checked RealOEM.com and checked the part numbers for your car, you would find that the Left and Right do carry two different part numbers. Though I cannot say with certainty whether or not the Vines Control Arms that you purchased would work/ are interchangeable. If you follow the link to RealOEM, you will note the different number at the end of the listed part number/ they list a left and right side part number. http://www.realoem.com/bmw/showparts...64&hg=31&fg=05 If you want quicker results rather than the tried and true method of attempting and failing, send LCSman a Private Message. He could offer a little bit more insight on these, as I seem to recall him recommending them in the past. That would lead me to believe that he has personal experience with thei products. On a side note, where did you purchase those from? I have been looking at getting those. If I couldn't find them by doing a simple search, I was just going to purchase the Bavarian Autosport control and thrust arms with their polyurethane bushings pressed in. Hope this helps.
M540i is offline
Old 10th August 2007, 06:36   #3
CWY_M5
CWY_M5's Avatar
ebay - Vines Auto. Or you can go on Vines Auto website (google it).
I have seen people saying good things about them, but so far, I'm less than impressed.
1. order delay, I paid for them on 7/21, still don't have everything. And that's with email exchange and promises of shipping within 2 days
2. Still don't have thrust arm, shipped separate, via slowest GROUND, due to arrive next week.
3. Got the identical arm
From the looks, I really hope they are really good quality. There is a cut on the control arm (both of them) that I do not see on the OEM ones. I'll take picture later. Let's hope quality is good.
See pictures below. Left is brand new VINES arm, Right is OEM arm. Do you see the cut I'm talking about?
CWY_M5
E39 M5
'00 Titan Silver
99k miles
110k miles
Other BMWs:
- Power chipped
- V1 direct wiring
- V1 direct wiring
CWY_M5 is offline
Squeaking front control arm bushings tranck E39 M5 and E52 Z8 Discussion 6 10th October 2006 13:18
How much for O2 sensors, plugs and control arm bushes? [UK Dealer] wiggis E39 M5 and E52 Z8 Discussion 2 27th September 2006 01:51
Control arm replacement/question KevinM E39 M5 and E52 Z8 Discussion 3 2nd September 2005 09:10
Page generated in 0.10993 seconds with 11 queries
