I bought the VW MAFs with partnumber:
06A906461 and was very happy with the extra power and smothness i got. But someone told me that the VW MAF's do not have a intake air temperature sensor, as the BMW MAFs have, so I checked my VW MAF's and they don't have the temperature sensor. When checking for errorcodes I found a errorcode for Intake Air Temperature sensor Performance. Maybe this is why some of you get the SES light after replacing the MAF's with VW ones?
Anyway, I figured out how to fix this issue by transfering the temperature sensor from the "bad" BMW MAF to the new VW MAF and it fixed the errorcode since the DME/ECU is getting correct IAT signals now.
I did some research in WDS to see how the sensor is connected inside the MAF and the sensor is directly connected to the pin1(signal) and pin3(ground) and the VW MAF has the connectors for IAT in place but not the sensor.
Obviously this does not apply if you have a IATS kit installed since IATS disconnects the temp sensors in the MAF.
I made a small DIY webpage on how to fix this issue here:
http://tozzynet.se/BMW/VAG-BMWmaf/maffix.htm
Hope this helps someone
/Thomas
