Old 9th August 2007, 22:26   #1
matthi_lampe
matthi_lampe's Avatar
Garage: BMW E39 M5 Grey
Send a message via MSN to matthi_lampe Send a message via Skype™ to matthi_lampe
Problems with my M5
Hi guys,
i'm new here and i have problems with my E39 M5
It al started last monday i went to an BMW meeting at a track in Zolder.
There some guys with an E46 M3 and another E39 M5 told me they could arrange a upgrade for my Nav. I told them they could try to upgrade it.
But my whole Nav blocked. The Cd with the upgrade wouldn't come out of the Nav thing..
Than they unhooked the battery to reset the Nav. After long working it finally came out. But while we drove home the car acted very strange.
the whole time the speedo meter didn't work and the screen fell out en the car drove strange. Then when I came home a friend told me to check the battery in the back. And yes it wasn't how it's supposed to be. I setted everything right and the car drove normal again. But today, suddenly the car shuts completely down. It doesn't want to do anything. It wouldn't start, the trunk won't open, nothing worked. Even the interior lights wouldn't work.
I just have the car for 6 weeks now. And I had around 2600 euro on costs with BMW. Now this happens, does anyone knows what it might be?
thanks!
matthi_lampe is offline
Old 9th August 2007, 22:41   #2
Tim NL
Tim NL's Avatar
Garage: Soon an M5
Matthi,
Have you tried to open the trunk?
Can you go in from the inside of the car?
It might be the battery again
Cheers,
Tim
Tim NL is offline
Old 9th August 2007, 22:42   #3
matthi_lampe
Originally Posted by Tim NL View Post
Matthi,
Cheers,
Tim
Tim,
The trunk wouldn't open.
i can get in the car and out but the car wouldn't close either...
Matthi
Old 9th August 2007, 22:46   #4
Tim NL
Tim NL's Avatar
Garage: Soon an M5
There must be a way to open the trunk with out power...
Any one??
Tim NL is offline
Old 9th August 2007, 23:15   #5
MGZ
MGZ's Avatar
Garage: M5 e39 Carbon Black
Sales Feedback: (3)
Use the master key in the lock. Turn it to the left and the the lid will open a little. (I think this is in the manual...)
MGZ is offline
Old 9th August 2007, 23:19   #6
matthi_lampe
Already tried that. Also doesn't work...
Old 10th August 2007, 00:33   #7
rassi
rassi's Avatar
Garage: '02 BMW M5 (Carbon black / black leather)
As said above, you need to turn the master key counter clock-wise and use a bit of controlled force. Have a look at Locked myself out of trunk.
Your problems sounds like a dead battery or the negative lead that has come off. Good luck
Anders
Stock apart from Eisenmann Sport, E60 545 short shifter mod, MKIV nav and Intravee II
ex '01 BMW 530D Touring (Sterling grey / beige leather)
ex '98 Mercedes C43 T AMG (Smaragd schwarz / black leather)
ex '99 BMW M Coupé (Cosmos black/ black-kyalami leather)
ex '93 Alfa Romeo 164 24V Super (Silver / black leather)
rassi is offline
Old 10th August 2007, 00:42   #8
jclyman
jclyman's Avatar
Turn the master key all the way to the left ... it may be hard to turn as you will be engaging the mechanical locking system which has probably never been used. It's in the Owner's Manual (page 32 in the 2003 manual).
- Daniel Boorstin
jclyman is offline
Old 10th August 2007, 04:24   #9
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Jump the car. Open hood, there is a remote battery terminal. It is on the drivers side on U.S/LHD cars. Complete the circuit by grounding against metal along the fender or in the engine compartment. That will at least give you enough power to open the trunk to check the battery itself if you can't get the trunk open manually.
To avoid any power spike, consider turning on the running lights before you hook up your jumper battery so there is no jolt to the electrical system.
gsfent is offline
Old 10th August 2007, 14:27   #10
matthi_lampe
Thanks guys,
my car starts again. Like Rassi said the negative lead has come off. Now it's just mather of fasten it good!
Feedback on E60 M5 problems? Bagger E60 M5 and E61 M5 Touring Discussion 18 21st July 2006 17:05
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 22:23
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav Most Memorable Threads' 0 4th July 2004 22:13
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 22:13
OT: Z8 Roadster Millie Miglia E39 M5 and E52 Z8 Discussion 9 4th April 2001 01:25
Page generated in 0.15336 seconds with 11 queries
