Old 8th August 2007, 14:29   #1
maxm5
maxm5's Avatar
Garage: 2001 E39 M5 Carbon Black
Oil consumption back to normal after replacing oil seperators
My beast generally uses about one litre of oil per 1000 miles up until about three months ago when it started using about one litre per 300 miles.
I thought I'd try replacing the oil seperators before doing any major work on the engine and the results were instant.
Here's the diagram showing the parts..
http://www.realoem.com/bmw/showparts...53&hg=11&fg=15
It took me about 30 minutes to replace them but I should warn you that it will take alot longer if you have big hands! I still ended up with a few missing knuckles when I had finished.
All I had to remove was the air intake hoses attatched to the MAFs and intake manifold. If you have big hands I think you'd need to remove the top engine cover first.
I actually replaced the seperators about 6 weeks ago but wanted to get 1,500 or so miles on the car before posting my experience.
The parts cost about £48 ($96), which I have almost saved in oil costs in the last few weeks!
The old ones looked a bit clogged up with gunk which you'd expect after 100k+ miles. I think the oil seperators condense oil vapour which then goes back into the cylinder head rather than being burnt in the exhaust - I'm guessing the clogging of my ones causes all of the oil to get burnt in the exhaust rather than being put back into the engine.
FYI - My beast now has 111k on the clock and I use Mobil 1 which does get used up about 20% quicker than TWS. Oh yeah and I do not baby my car!
Max
____________________________
Drive it like you stole it.
2001 Carbon Black M5 - Most options fitted.
1995 Calibra 4x4 Turbo-Don't laugh 'til you drive one. GONE
1985 RE1900 VW Scirocco - Very special, every mod possible. GONE
1981 MK3 Ford Escort - Tried to make it look like an XR3i with five doors! GONE
maxm5 is offline
Old 8th August 2007, 17:53   #2
Mike Krieger
Mike Krieger's Avatar
Garage: 2000 M5 Oxford Green
I have always suspected that bad separators are a contributor to carbon build up in the heads. When they go bad the entire plenum gets sprayed with oil and I have seen puddles of oil in mine before I changed out the separators. When that gets sucked in and doesn't burn completely, I think it coats the combustion chamber and backs up into the ports in the head and blocks the secondary air passages.
2000 Oxford Green/Extended Caramel
Split folding seats with ski bag
Alacantra headliner
Mk. IV nav upgrade v.27
16:9 monitor
UF Motorsport Intake air temp. sensor relocation
Bimmernav Bluetooth
PowerChip 93
Royal Purple Synchromax
OEM First Aid Kit
Hardwired V1
AA CAI
Bavarian Auto Angel Eye update
Supersprint headers, SS X-pipe and Evo Racing Cats
Dinan Stage 2 suspension
Dinan 3.45 Diff
Mike Krieger is offline
Old 8th August 2007, 18:38   #3
richie_rvf
richie_rvf's Avatar
Garage: BMW E39 M5 Le Mans Blue
Max,
was that the price each or for both?
Sounds like it would be a good idea to replace them seeing as how they are so in-expensive regardless of oil consumption.
Cheers for the feed back,
Richie.
richie_rvf is offline
Old 8th August 2007, 18:46   #4
maxm5
maxm5's Avatar
Richie
That was for both.
Max
maxm5 is offline
Old 8th August 2007, 22:24   #5
Silver_Menace
Silver_Menace's Avatar
Garage: 2002 Titanium Silver M5
Are these oil separators something that could be cleaned at regular intervals with petroleum distillates? I surmise the answer is no without seeing the interior of an oil separator. It's not a horrible price for piece of mind.
Silver_Menace is offline
Old 8th August 2007, 22:53   #6
Ken21
Ken21's Avatar
Garage: E39 540i,E39 M5
Sales Feedback: (5)
Send a message via MSN to Ken21
My beast consume around 1L/600km for the past few months and i also think it is the oil seperators so i just ordered both oil seperator and all new hose for it and hope it will return back to normal
99 AVUS E39 M5 ---
Rogue Octane SSK + WSR
Rogue Tranny Mount
Whalen Custom made shift knob
Vorsteiner GTR Double Sided CF Hood
Angel Ibright v3.0
Hella Euro Angel-Eyes Headlights
Lamin-X headlights + fogs
Hella Celis Tail-Lights
Defi Control Unit II
Defi BF Oil-press Gauge
Innovate XD16 A/F Gauge Kit
Voltphreaks 6.5lbs Lightweight Battery
UFMotorsport IAT Relocation kit
DIY'd AA Style CAI
Supersprint X-pipes
Magnaflow 14816
Front Brembo 6pots w/380mm Rotors
Rear Brembo 4pots w/345mm Rotors
GC Coilovers ( Track Springs )
Custom-Fit 3.416 Diff
TC Design Rear Swaybar Brackets
Dinan Rear Swaybar
19" Iforged Swift w/custom offset
Pilot PS2 in 275 F and 295 R
Hardwired Beltronic RX65
Stebel Air horn @139db
M3 ZHP Alcantara Steering Wheel
Schroth 4-pts Harness
Recaro Sportline seats
Exotics Tuning Programe-39 Front Lip
Exotics Tuning Programe-39 Fog Light Covers
Exotics Tuning Programe-39 Aero-finned Exhaust Diffuser
Ken21 is offline
Old 9th August 2007, 09:37   #7
maxm5
maxm5's Avatar
Silver
I guess you could clean them out, though being a sealed unit there may be some internals that you can't get at to clean. If I get the chance I'll cut the old ones open and take a picture of the x-section.
Ken - If you DIY, then the hard part is gettin the bottom hoses back on.
Max
maxm5 is offline
Old 11th August 2007, 19:05   #8
derheilige82
derheilige82's Avatar
Garage: 2000 M5 Carbon Black
Send a message via MSN to derheilige82
Any updates on the consumption or new observations?
Dinan CAI
Steel Braided Brake Lines
Mark III Computer
FS: OEM Exhaust Brand New:
http://www.m5board.com/vbulletin/sho...hlight=exhaust
FS: Parting Out E39 M5, Many Random Parts Available Including Dinan Flywheel!!!:
derheilige82 is offline
Old 13th August 2007, 10:11   #9
maxm5
maxm5's Avatar
Derheilige
No change in the last five days - covered another 800 miles or so and the oil consumption seems to have settled down at 1L per 1,000 miles.
Max
maxm5 is offline
Old 13th August 2007, 14:02   #10
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
Originally Posted by maxm5 View Post
Silver
Max
I'm told it's just a simple vortex arrangement inside so you can just blow them through with an air line. My oil consumtion is so high this is my first job for next weekend!
100%Cocoa is offline
Possible cause of oil consumption problems Gandhi E39 M5 and E52 Z8 Discussion 23 15th September 2009 03:21
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 61 7th January 2009 11:06
Oil Change - Mityvac 7201 Review BimmerHead E39 M5 and E52 Z8 Discussion 2 8th January 2007 16:10
Checking oil, back to basics? kwalls E39 M5 and E52 Z8 Discussion 25 29th April 2003 02:04
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
Page generated in 0.20728 seconds with 11 queries
