Old 8th August 2007, 00:34   #1
Obioban
Obioban's Avatar
Garage: 2005 M3
Do 4 piston 355mm brembos fit behind rear OEM 18s mounted on the front?
I'm debating between stoptechs and brembos... I know the stoptechs fit behind the front 18 without spacer, but would brembos fit behind a rear OE 18 mounted on the front (square setup)?
I know they do on my e46 (exact same situation-- rear OE 18s on the front, 4 piston 355mm brembos)
Mod List
AIM: Obioban
Obioban is offline
Old 8th August 2007, 00:54   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i think you can get a template off dave zeckhausen's site that you put inside of the wheel to see if there is clearance. IIRC, when i was looking at doing rear brakes, i thought Dave had told me there was actually less clearance behind the rear wheels vs the front, but could be wrong.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 8th August 2007, 01:00   #3
Mike Krieger
Mike Krieger's Avatar
Garage: 2000 M5 Oxford Green
I think you need a 5 mm spacer just to clear the stock brakes when you put the rears up front so there is no way it will clear a BBK.
2000 Oxford Green/Extended Caramel
Split folding seats with ski bag
Alacantra headliner
Mk. IV nav upgrade v.27
16:9 monitor
UF Motorsport Intake air temp. sensor relocation
Bimmernav Bluetooth
PowerChip 93
Royal Purple Synchromax
OEM First Aid Kit
Hardwired V1
AA CAI
Bavarian Auto Angel Eye update
Supersprint headers, SS X-pipe and Evo Racing Cats
Dinan Stage 2 suspension
Dinan 3.45 Diff
Mike Krieger is offline
Old 8th August 2007, 01:35   #4
Obioban
Obioban's Avatar
Garage: 2005 M3
This is sad news.
Mod List
AIM: Obioban
Obioban is offline
Old 8th August 2007, 02:32   #5
supratony
supratony's Avatar
Garage: 2002 BMW M5 Sterling Grey | 1997 Supra Turbo 6sp
Sales Feedback: (5)
The rear wheels will fit with 3mm spacers up front if you got with the 355m Brembo's. I've got this setup right now and it's working well. You can get 3mm spacers from TireRack.com, and you'll also need longer lugs (I've got an used set for sale if you are interested...)
supratony is offline
Old 8th August 2007, 07:22   #6
Obioban
Obioban's Avatar
Garage: 2005 M3
Woo hoo!
Just to confirm, you have 355mm 4 piston monoblock brembos (not stoptechs)?
I already have a stud kit or I'd hop all over that.
Thanks!
Mod List
AIM: Obioban
Obioban is offline
Old 9th August 2007, 00:04   #7
supratony
supratony's Avatar
Sales Feedback: (5)
Yes, I've got the 355mm 4 piston brembos up front with 3mm spacers, longer studs, OEM 9"5 rims w/ 275 tires.
You'll love the extra grip.
Originally Posted by Obioban View Post
Woo hoo!
Thanks!
Looking for Track Brake pad options for factory brakes Lscman E39 M5 and E52 Z8 Discussion 46 15th March 2004 08:22
Brembo 355mm front brakes only require 3mm spacers - not 5mm. DZeckhausen E39 M5 and E52 Z8 Discussion 14 14th March 2004 19:58
275/35 18s on stock rear rims + front installation bbloch1114 E39 M5 and E52 Z8 Discussion 1 1st May 2002 17:53
Brembos Installed Front And Rear calbobba E39 M5 and E52 Z8 Discussion 8 5th February 2002 07:13
Page generated in 0.14053 seconds with 11 queries
