Remove resonators? - BMW M5 Forum and M6 Forums
Old 4th August 2007, 02:18   #1
SoCalJD
SoCalJD's Avatar
Garage: 2002 M5 Bluewater
Remove resonators?
Although I love the sound of my Sebrings...I can never leave things well enough alone....so I'm thinking about this. The problem is that- nobody alive can tell me what to expect. My man at AGA said: "It'll be stupid loud. Or not. I'm not sure". I don't think they're too loud...although the LACS seems to think otherwise. I don't mind loud...but I wouldn't want "stupid loud". Any thoughts? I'd hate to do the work and then find out I hate it.
"The whole world was astonished and followed The Beast." Rev 13:3
SoCalJD is offline   Reply With Quote
Old 5th August 2007, 02:18   #2
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
You are unlikely to get an answer unless you ask someone w/ Sebrings and your exact setup.
The problem with guessing what it will do is that resonators are designed around a specific frequency of input and therefore only perform the intended increase/reduction in volume/frequency around that one input frequency.
By changing over to Sebrings you have changed the basic characteristics of the exhaust, and hence your "starting point" for sound is different that those of us with stock systems (or even different aftermarket systems).
Trying to guess what will happen is the same as trying to guess whether the next stop light you come to will be red or green. You basically have a 50/50 chance of getting it right (louder or quieter), but if you have driven the route before (ie. performed the same modification) can make a much more educated guess.
d-
DouglasABaker is offline   Reply With Quote
Old 5th August 2007, 13:29   #3
SoCalJD
SoCalJD's Avatar
[quote=DouglasABaker;1102884]You are unlikely to get an answer unless you ask someone w/ Sebrings and your exact setup.
AFAIK, I have the only E-39 on the planet with Sebrings, so that ain't gonna happen.
Old 5th August 2007, 14:50   #4
DouglasABaker
Have you tried calling Sebring then? They would be in the best position to give you an answer. The other option would be to cut off the resonators and try it. Worst that happens is you have to put them back on with a pair of couplings.
d-
Old 6th August 2007, 00:47   #5
Evil One
Evil One's Avatar
Garage: E39 M5 Avus Blue
The resonator removal didn't make a LOT of extra noise when I did it. More of a better note. I understand your 'zorst is not stock, what I'm trying to say is that I don't think the res' has much of a quietening effect, more a 'tone' effect, like Doug said, based around a certain set of freqs.
It's not hard to remove in such a way as to allow re-installation later. Give it a go and post some vids for us!
Cheers
Of all the things I've had and lost, I miss my mind the least.
Evil One is offline   Reply With Quote
Old 6th August 2007, 00:58   #6
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
What type of muffler is the sebring? Chambered? Straight through? The main thing you will probably notice is the in-cabin resonnance. Not so much the little extra outside noise.
E55AMG2 is offline   Reply With Quote
Old 6th August 2007, 02:17   #7
SoCalJD
SoCalJD's Avatar
Not sure. I'm the detail guy...not a wrench.
Old 6th August 2007, 06:43   #8
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
The detail guy is the one who's supposed to know, the wrench just does the installs
Old 6th August 2007, 07:19   #9
Evil One
Evil One's Avatar
I know JD's isn't stock & mine is, so this may not be entirely applicable, however when I removed my resonator there was no resonance or 'boominess' in the cabin at all. It just sounded a wee little bit louder than stock inside - so little in fact that if you didn't compare them back to back you'd swear it was a stock system.
Outside the car it's a similar story, except that when you give it a good throttling the car has this really nice crackling note to it that the stocker never did, and is a little louder as well.
Still, at no rpm do you get any 'boom'. Instead you hear what sounds like every individual piston firing - like an infinite series of little far away explosions each one discrete from the other.
I love it as it is now (as you can probably tell ) but I recognise that what 'does it' for me may sound like complete rubbish to someone else. As in everything it's horses for courses.
I should add that I replaced my resonator with a fabricated x-pipe, not 2 bits of straight through piping, though I don't know how much difference that makes.
Old 6th August 2007, 10:26   #10
robluvs2xlr8
robluvs2xlr8's Avatar
Garage: 2010 Kawasaki Ninja
I have Dinan exhaust and I took off the resonators.
It's louder, but not stupid loud IMO. When you go wide open throttle, that's where it will really get loud.
-2007 BMW Z4 M Roadster
(Interlagos Blue / Black)
stock
-1992 Honda Civic LX
(White / Tan)
30mpg
-2001 BMW M5
(Royal Red / Caramel)
-Sold-
robluvs2xlr8 is offline   Reply With Quote
E39M5 Rear Deck removal DIY (long and detailed) jaj E39 M5 and E52 Z8 Discussion 13 17th December 2011 11:42
Laser Pro Park (LPP) Group Buy (Laser Jammer) Road Runner M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 28 17th July 2007 02:56
How can I remove the rear seat backs? KEV-BMW E34 M5 Discussion 4 10th January 2007 09:42
E65 HID Fog Lights Installation Guide umnitza E39 M5 and E52 Z8 Discussion 0 1st January 2007 22:59
Feedback on removing resonators? LI-M5 E60 M5 and E61 M5 Touring Discussion 4 22nd July 2006 01:29
