Old 24th July 2007, 18:14   #1
jp7152
Garage: Boston Green E36 Euro M3
Upgrading M5 non DSP front speakers
I have an M5 2001 with no DSP and wanted to upgrade the front speakers as they sound stressed at anything above a medium volume.
I have found these on ebay, however after bidding it looks like they may be from a non DSP car, so exactly the same as I have already?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=140134066554
Could someone advise if these would be suitable to upgrade my front speakers with?
Thanks in advance.
jp7152 is offline
Old 24th July 2007, 18:48   #2
stevieb
Garage: 2001 E39 M5 Silver
Guess you'll find out soon enough now ;-)
More serious - I have the same setup, so am interested what improvements there can be within the standard door cards. Info on suitable aftermarket drivers anyone?
2001 BMW M5
2002 Audi S8
1979 Moto Guzzi Le Mans
stevieb is offline
Old 24th July 2007, 21:22   #3
Chessie
Chessie's Avatar
Garage: '02 BMW M5 - Titanium Silver
BSW
Have you checked out the options available from BSW?
http://www.bavariansoundwerks.com/index.php
-c
Chessie is offline
Old 24th July 2007, 22:33   #4
jp7152
Thanks.
I am looking to keep costs down as much as possible.
Is it possible to run the M Audio Subs off the standard sound system or will it require an additional amplifer?
Is the M Audio an addiitional amplifer running alongside the standard one or does it just replace the standard one?
jp7152 is offline
Old 24th July 2007, 22:37   #5
BMWMPWR
BMWMPWR's Avatar
Garage: Joji Nagashima designed BMW - I hope you know who this guy is!
Sales Feedback: (6)
You can find a set of tweeters and 5.25inch mids for about $150. Brands like Polk Audio, Boston Acoustics, etc. Figure that to be about £75??
Inexpensive upgrades that make her sing so much clearer and better I might add.
Pretty much plug and play.
Neil's 2003 Bluewater Metallic ///MRS
Behind the Matte Black Kidneys: Active Autowerke Cold Air Intake, Super Sprint Exhaust & X-Pipe from ModBargins, Dinan SSK, Dinan Software, Dinan Lightweight Flywheel.
Modifying and Improving Creature Comforts & Driver Aides: Valentine 1 with Jaric Designs Stealth One, Defi VSD X Heads Up Display, TEC Cup holder, Polk Audio Tweeters, MB Quart Mids, Twin JL Audio 10w3v2's with center port through skipass, Alpine PDX4.100 and PDX 1.600. DVD player with Video Module, Rear Backup Camera and dual 7" head rest monitors along with Intravee for iPod via 2point5 specdoc. Stoptech Big Brake Kit, centric Posi-Quiet Semi-Metallic Brake Pads from Zeckhausen Racing and TC Design Rear Sway Bar Brackets.
Working towards Pure Aesthetics: Hella Euro Clear Headlights with Upgraded 6000K D2S HID Low Beams protected with Lamin-X Headlight & Foglight Protective Film ALL from üm•nitza, Predator ICE Angel Eyes w/K2 LED Mods, 6000K HID Fog Light kit rolling on Ground Control Coil Overs on a set of Cargraphic 19x9 & 19x10 3 piece forged wheels wrapped in 255.35.19 & 285.30.19 Michelin PS2.
When you turn your car on, does it return the favor? -
BMWMPWR is offline
Old 24th July 2007, 23:47   #6
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Unless these were from an m-audio (which they weren't since it M-Audio has to midrange) I'd be willing to bet you now own 2 sets of the same speakers.
I got my MB Quart DUA513's for $69USD per set on Ebay and they are a drop in replacement. 4 sets, $250 total. Best money I've ever spent.
d-
DouglasABaker is offline
Old 24th July 2007, 23:50   #7
dave_gt
dave_gt's Avatar
Garage: E39 M5 Le Mans Blue
jp7152 - they may be the same speakers as you already have, or a little different, but I can tell you that they look very similar to the ones I took out of my non-DSP car when I upgraded the stereo. The M-Audio amplifier replaces the standard amplifier rather than being an additional item.The M-Audio subs would need an extra amplifier to power them, but if it was my money I wouldn't bother.
The E39 M5 stereo is a complex subject and there are many informative threads on it. The three varieties of M stereo are standard, DSP and M-Audio; the standard system that you have is the easiest to upgrade. If it were my money and I wanted an increase in quality without spending loads of money, the order of upgrades I'd do would be:
1) Replace the stock front woofers and midrange with some decent 5.25" components. They should fit straight in and wouldn't cost the earth but should make a significant difference. The stock tweeters remain so some care is needed with speaker sensetivity. £75-£100 should do it if you fit them yourself.
2) Add a sub woofer and amplifier. A single 12" sub and smallish amp (go for quality rather than claimed power output) would make a massive difference. For someone who genuinely knows what they are doing it is a fairly straight forward job for your car. Budget £200-£250 plus fitting for sub, box and amp.
Hope that is of some help.
2001 M5, Lemans Blue / Silverstone
Standard except for a few bits & stereo:
6.5" Focal components, 10" Directed sub, IceLink, JL Audio & Directed amps (hidden). Predator ICE, Stealth bulbs, V1, Roadpilot
1990 Mazda MX-5 (brilliant) 1998 Nissan Primera GT (modded)
dave_gt is offline
Old 25th July 2007, 00:21   #8
jp7152
Thanks Dave.
Are the M Audio subs worth £40 ?
I would like something that doesn't take boot space if possible and is easy and cheap to fit.
jp7152 is offline
Old 25th July 2007, 00:35   #9
dave_gt
dave_gt's Avatar
Don't forget you'd need an amp to power them, but £40 sounds cheap. They are made by Nokia FYI. I don't know how much installation work is neccessary for the subs themselves. The amp would need fitting by a professional who understood the M5 stereo and had access to the wiring diagrams (easily available on the net).
You can get a new 12" Alpine sub in a box for £70ish and an alpine amp which would power it for £99 and I expect it would easily outperform the M-Audios. It'd need fitting though, but that would be the case with an amp to power the M-Audios anyway. It shouldn't take up much boot space, but i've seen pics of some really ingenious sub installs in the M5 where they don't rob any space. Take a bit of work though.
dave_gt is offline
Old 25th July 2007, 00:40   #10
jp7152
Ah great.
I have bought the speakers in the auction anway so will go with those and the M Audio speakers for now.
There's always ebay if they don't perform.
Would you have any reccomendations on an amplifer?
I don't want something massively powerful, just rather have the subs doing some of the work rather than the front speakers being too busy.
Is there a difference in the front speakers on a DSP car vs a non DSP car?
jp7152 is offline
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 01:11
Alpina B8 Brake pads CHEAP! mill ALPINABoard.com | BMW Alpina Discussion 50 13th May 2008 12:28
BMWNA pressrelease on 6-speed manual M5 kees E60 M5 and E61 M5 Touring Discussion 10 9th February 2008 07:50
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 17:08
Page generated in 0.17960 seconds with 11 queries
