Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks > E39 5 series Forum
E39 5 series Forum Dedicated to the E39 5 series.
Old 27th October 2005, 22:15   #1
mossy
Garage: 2000 E39 M5, Avus + Tan
M5/540 cabin temp sender fault
I have a "snag" with my late '99 M5, the climate control sort of works but to get a half stable temp you have to set it at 30 odd degrees C. I took it to my local BMW dealer who pluged it into the box of tricks and came out with a fault code "cabin temp sensor", The parts department cant supply a sender for a M5 without replacing the whole climate control unit "£450 for the bit + coding". Intresting enough they will supply just the sender for any other 5 series 540 etc. Is the 540 climate control different to an M5?? Has anyone replaced the sender one its own??
mossy is offline
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
Climate control fault E39 M5/540 mossy M5 E39 and E60 tips & tricks 0 27th October 2005 22:13
M5 cabin air temp sensor mossy E39 M5 and E52 Z8 Discussion 0 27th October 2005 22:10
Page generated in 0.07057 seconds with 11 queries
