Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks > E39 5 series Forum
E39 5 series Forum Dedicated to the E39 5 series.
Old 26th November 2003, 21:32   #1
ponloeu
Garage: BMW5 silver
Bad brakes?
I have a 2003 525 automatic with sports package Is it normal for my car to roll back when parking on a 3-5 degree drive way, when I apply just the hand brakes with out putting the car into P(parking gear)? One more question, I can hear my brakes when I use the foot brakes at a stop light, it that normal? It’s not supper loud but I can hear a grinding noise. I use to own a Honda Prelude and when I apply the foot brakes it was silent.
Thank you,
Ponloeu
ponloeu is offline
Old 26th November 2003, 23:25   #2
TCM
TCM's Avatar
The parking brake on the E39 is known to be very weak. In fact, we had a thread on this about a month or so ago. It basically boils down that you need to get it adjusted every couple of months. As far as the noise, that is not normal. If your brake pad warning light is not on, I would assume you may have a rock stuck between your rotor and backing plate. check to see if this is the case and if so, you can remove it with a long object. Hope this helps.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Brake Rotor Issue Joe Lapicki E39 M5 and E52 Z8 Discussion 29 26th December 2002 16:42
Are stock e39 M5 brakes as good as stock e46 M3 brakes? BeastPower E39 M5 and E52 Z8 Discussion 10 27th November 2002 11:27
M5 brakes / clutch are bollocks! slider E39 M5 and E52 Z8 Discussion 4 7th October 2002 23:46
Next project! - New brakes but have some questions atomic80 E39 M5 and E52 Z8 Discussion 9 16th April 2002 23:29
Page generated in 0.08745 seconds with 11 queries
