Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks > E39 5 series Forum
E39 5 series Forum Dedicated to the E39 5 series.
Old 30th August 2003, 05:41   #1
Lscman
Garage: E39
Anyone hear of using E39 M5 rad on 540i?
The early E39 rads are garbage primarily because the flimsy plastic upper rad hose connector breaks off every 50K miles. Anyone hear anything about retrofitting an E39 M5 radiator into a 540i?
Sorry if this is considered off-topic. Thanks for any replies.
Lscman is offline
Old 30th August 2003, 07:36   #2
TCM
TCM's Avatar
The 540 radiators are known for snapping but I have never heard of retrofitting an M5 one on there. If memory serves me correctly, the replacement radiator has a reinforced neck. I do not see a reason why an M5 radiaotr could not be used though as the area is the same and there is plenty of room in the 540 engine compartment.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 30th August 2003, 16:23   #3
Lscman
Garage: E39
Certain enthusiasts have told me the OEM '96 thru '98 528i/540i radiator design has not yet been modified to prevent failure. Folks are replacing them again and again like Walmart light bulbs and some are ruining their motors from no coolant. Unfortunately, the aftermarket cloned the original flawed design.
Lscman is offline
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4492 Yesterday 13:54
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 01:11
Dinan Exhaust AlbertM E39 M5 and E52 Z8 Discussion 5 6th October 2000 19:11
Page generated in 0.14278 seconds with 11 queries
