What these codes means ? plz help - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E39 5 series Forum
E39 5 series Forum Dedicated to the E39 5 series.
Old 3rd August 2012, 12:26   #1
friends11
Garage: BMW E39 530i Blue
Hello gentlemen,
last night I had trouble with my car and I scanned it with with my computer.
This is what came up..
CB Fuel Trim bank 2 control limit
CA Fuel trim bank 1 control limit
E3 Fuel trim bank 1, permissible range exceeded
E4 Fuel trim bank 1, permissible range exceeded
Tried to erase but it came up again,
also RPM is being funny not regular.
plz help
friends11 is offline   Reply With Quote
Old 9th August 2012, 09:36   #2
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
I assume this is from the M54 engine...usually it is MAF or fuel pressure regulator that pops up these codes
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
The Following User Says Thank You to vantaam5 For This Useful Post:
chowdah (9th August 2012)
Old 5th January 2013, 04:06   #3
upstateimports
Garage: 09 XC90 Green
There 4 possible causes for these codes- 1 air flow sensor boots dry rotted- 2 PCV hose has a hole (usually from separator to dipstick tube)- 3 Mass Air Flow Sensor- 4 DISA valve leaking.
upstateimports is offline   Reply With Quote
Can't find out what this word means Project5 E39 M5 and E52 Z8 Discussion 20 3rd May 2012 21:42
Does anyone know what this code means? Blown03HD E39 M5 and E52 Z8 Discussion 1 13th April 2011 19:59
HELP!!! Can ANYONE tell me what this code means?? David Ajax III E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 13 2nd January 2011 09:15
Current means of Employment? Tone Off Topic Forum 3 8th October 2003 16:14
B10 3.5 means business! alpinadvl Owners Gallery 7 31st July 2001 15:40
