Need help installing driver's door air bag - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E39 5 series Forum
E39 5 series Forum Dedicated to the E39 5 series.
Old 25th July 2012, 05:39   #1
gnome
gnome's Avatar
Garage: 2000 e39 540i Sport w/2002 engine
Just picked up a 2000 540i, sport option. Drives nice, showing some signs of wear, trying to get it back to a nicer state as the original owner let a few things go. The drivers door has NO airbag (it was replaced with a better door from a donor car without the air bag).
Airbag light is on, I just bought the airbag and mounting bolts from a parting out car - is there a way to install the missing airbag in the door without having to remove the door panel? I read the great DIY on this forum for removing the panel to fix the window regulator, but is there an opening that I can access just for the airbag area?
Also, I plan to do this with the battery disconnected of course. Will the airbag light reset by itself or do I need an SRS reset tool? Also with the airbag light on, does that mean that no airbags will deploy in an accident? I don't want my son driving the car if that is the case.
Any help is much appreciated.
Gnome
gnome is offline   Reply With Quote
Old 26th July 2012, 04:55   #2
roverguy10
roverguy10's Avatar
Garage: 2003 e39 M5 Carbon Black & 1991 e34 M5
Need to take the panel off. Its simple and aught to take an hour or so. Don't miss the screw in the front hvac duct..
When you attach the airbag plug, good practice is to not stand in front of the airbag. The system is grounded and the airbag shunted but it doesn't take much to set off the airbag.
You so need a reset tool afterwards to the best of my knowledge.
Sent from my Galaxy Nexus using Tapatalk 2
roverguy10 is online now   Reply With Quote
The Following User Says Thank You to roverguy10 For This Useful Post:
chowdah (26th July 2012)
Need Picture of Rear Ski Bag Door a_ok2me E39 M5 and E52 Z8 Discussion 26 17th May 2012 06:20
2003 LeMans M5: rear door air bag question jmstoker E39 M5 and E52 Z8 Discussion 4 12th October 2011 15:47
E39 For Sale: Lower Air Grill with Aluminium Brake Air Duct Rings, OEM Brake Air Ducts and Front Driver's Wheel Liner Panos Parts / Other For Sale or Wanted 12 13th February 2011 18:53
Air bag warning light came on after working on door Rafael Gonzalez E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 6th April 2009 03:58
Air bag Activation Polynova E39 M5 and E52 Z8 Discussion 0 20th July 2005 07:05
