I had the beast in for service and repairs yesterday and spent $1K for parts and labour for the following:
-change leaking oil pan gasket
-oil and filter change
-replace air filter
-replace spark plugs
-replace distributor cap and rotor
-replace oxygen sensor
-lubricate clutch pedal <<<<
The beast runs just as well or better than it did before I took it in for service.
However, there is a VERY noticable increase in the engine noise entering the passenger compartment and it seems to be coming from under the dash on the drivers side.
What could the possible causes of this be? A ventilation system hose knocked loose from lubricating the clutch pedal? Something shifted or knocked loose as a result of raising the engine to change the oilpan gasket?
The mechanic that did the service indicated that the air filter was quite dirty so I thought for a moment that the increased noise was intake related. On further reflection though I'm hearing all the engine related noises louder than before, intake, valve train and the fan when the fan clutch is engaged.
This is one of those "It wasn't doing that before I gave you the car" situations which none of us ever like to be involved in.
Thanks in advance for your feedback.
