Old 6th July 2007, 16:44   #1
nebpor
Garage: Avus Blue E34 3.8 M5
Going for a service next week ...
Car is up for a major service, so I've booked it into a small independant in Glasgow. My Honda might not be ready for Spa & the Ring next month, so if not I'll be taking the M5!
List is:
Inspection II
Valve clearances
Brembo disks & DS2500 pads all round - the Mintex 1155s have deposited all over the disks and the brakes are shaking more than I do after a night on the vino
Fit new water pump (thanks to Nilconut)
Fit new oil tempreture switch to hopefully sort out the low oil temp prob
Motul RBF brake fluid
New MAF (old one might be ok, but I might as well fit the new one)
Hopefully Fix the "SLS Warning"
Investigate burning smell occassionally under full throttle & high revs that comes through the ventilation (not aircon related, it's currently broken and staying that way for the meantime)
Tighten up steering box
Investigate knocking from front suspension - aim to fix it next time as I'll probably poly bush everything if the EDC is getting refitted
I'll be printing out all the good advice on here and giving them that with the car - sure they're good, but might as well leave them it as reference - not sure they'll have serviced many M5s...
If Mike's man manages to get the EDC rebuild sorted before about 15th August then I will be fully refitting that to the car as well before I go on track.
Currently mulling over the chain tensioner upgrade, but as much as I search on here I can't find anything that says how many hours labour it might be - anyone know? Does it help that water pump is being done anyway??
Also, think the wiper tensioner is bust - am I right in thinking this is a very expensive job??
nebpor is offline
Old 6th July 2007, 17:24   #2
davidoli
Phew .....quite an exhaustive list .......I wouldn't bother fitting a MAF if the original is not coming up as faulty on a diagnostic .
S50B32 chain tensioner upgrade should take no longer than an hour !
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 6th July 2007, 17:29   #3
nebpor
Cheers - I've just ordered it from the dealer as well!
I know what you mean about the MAF, it's just I'd rather fit the new one then never have to worry about it failing
nebpor is offline
Old 6th July 2007, 17:47   #4
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
Stephen, remember (brake disc's) -- I can get any genuine bits with good discounts, I know Eastern have a tensioner on the shelf, probably get 20% off as Drencher never collected it. Just noticed this thread.
Cheers.
Phil.
Phlem5 is offline
Old 6th July 2007, 17:48   #5
nebpor
Doh! Forgot Phil.... just ordered a tensioner from Douglas Park in Glasgow ... don't think it's much anyway.
Disks from GSF (brembos) for about £170 and about that again for the pads from motorsport world.
nebpor is offline
Old 11th July 2007, 12:26   #6
nebpor
Handed over my pride and joy this morning - bloke at the garage was a gent and seemed to know his E34s as well.
There is too much work for him to do in one go as his colleague is off on holiday, so he'll do the brakes & Inspection II today then do the valve clearances on the cold engine in the morning - water pump and tensioner will wait till next week.
I had to get a train :-(
nebpor is offline
Old 12th July 2007, 19:21   #7
nebpor
Just got the car back .....
£726.15.
This didn't include changing either the water pump or fitting the new cambelt tensioner - he didn't have time so it will go back in for that.
Nothing wrong engine wise, in fact all in good condition, except the viscous coupling for the fan is faulty which means it doesn't cut in when the water heats up.
Impressed with service, bloke was nice and seemed honest - certainly knew the car well enough and I'll add him to the recommended Indys thread!
Need to do this lot when I put the new suspension on - explains wooly steering:
o/s track rod ends have play and boots burst
play in steering idler bush
play in o/s/f ARP drop link - replace both
Reaction arm bush splitting
Slight sweat on gearbox tail shaft oil seal
Slight sweat at diff n/s seal
Exahust back box mounting brackets missing from bodywork (!) - need to get some welded on.
All in all I'm happy - at least I know everything that's wrong.
Also got the name of a breakers in glasgow who specialises in BMWs so I can see if I can get aircon working again.
Car feels good, but new DS2500s need well ran in so I've not properly driven it yet.
Oh, he fitted the new MAF and the car ran like a dog! Splutterred it's way up the revs - refitted old one and all fine.
Once I get a chance I'll get pics/part numbers off the new one - don't know if it's a faulty unit or the wrong part - so much for an ebay bargaiN!
nebpor is offline
Tech: How to reset your service indicator greg E39 M5 and E52 Z8 Discussion 48 21st July 2009 05:02
My Ongoing Discussions with BMW NA RE: E60 M5 Extended Service Contract parkcitytom E60 M5 and E61 M5 Touring Discussion 28 10th April 2007 22:33
Service interval questions scar E39 M5 and E52 Z8 Discussion 4 21st March 2007 11:52
what do you make of this service history? chowdah E39 M5 and E52 Z8 Discussion 2 6th March 2007 07:47
BMW service loaner/customer service call JoeClothing E60 M5 and E61 M5 Touring Discussion 9 21st February 2007 03:48
Page generated in 0.12826 seconds with 11 queries
