Hello M5 fanatics.
I'm not an M5 driver (I do love this car!) but I bought a broken S38B36 and I'm starting to work on it. Is that the right forum to discuss about that?
When I bought the M5, with about 240 000 km on the odo, It was running on five cylinders only. The spark plug of the 1st cylinder was bent. I was thinking about a dead valve or piston... Last week-end, I managed to open the engine to discover the real problem : the 1st piston is dead and, execept some marks of aluminium to remove, the head seems ok
(phone pics for those two pics, sorry)
1st question :
Since I have some marks on the cylinder, I must bore it. Since I must bore the block and buy a new piston set, I'd like to overbore my engine. That's why I'm simply thinking of passing from 93.5 mm to 96.4 mm, like the S38B38. Do you know if I can use stock specs S38B38 pistons? I'll buy some new forged piston, but I would be less expensive buying B38 pistons than custom made pistons. Do you have the specs of B36 and B38 pistons, is it possible to fixe the B38 piston on the B36 rod and does the lenght between rod fixation and top of the piston the same?
Unfortunalty, when I stated to wash the head... AAAAAARRRGL, I saw a small crack... and two... ... and a total of five small cracks! All are located between the two exaust valves, valve seats not damaged.
I have this king of crack on five cylinders. Looking to the color of exaust valves and the blown piston... and knowing that the Motronic were opened at least one time before I bought it... no doubt about a "wrong" chip used with this engine...
I was about to drop the head but a friend of mine talked to his local aluminium specialist and it seems I could repair my cylinder head. For a very good price, he can :
- test the compression (won't continu if not tight)
- remove the valve seats
- repair the five cracks with "argon welding"
- install new valve seats (24 of them, by the wat)
- plane the head (if needed) and miror finish of the gasket plane
2nd question :
Do you think it's a good idea or am I totally dreaming about this king of repair?
Thomas Olivaux
PS : please excuse my english, hope it was clear for everyone :p
