Old 4th July 2007, 21:02   #11
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
As an Ex motor vehicle technician (although not BMW)
I've replaced a few sunroof mechanism and panels over the years.
Whats quite apparent is that the glass roof option (with blind) is more
complicated and will probably use a different headlining panel arrangement
to accomodate the Blind (which has a channel of its own) than a steel roof.
To make the blind work would entail getting all the parts from a donor car.
Dropping the headlining out of any car can be a pain, but the biggest pain
is putting it back in without screwing it up again !
I see another solution though guys....
when its sunny, open the steel roof.
when it rains...close the steel roof and practice going sideways.
///M5 the only substitute for capacity is even greater capacity...
Alan Archer is offline
Old 4th July 2007, 21:52   #12
de Witt
de Witt's Avatar
Garage: 1988 M5 (x2) 1991 M5 2008 M5
Send a message via AIM to de Witt
Would an E32 moonroof work in the E34?
{o,o}
|)__)
The E28 M5 FAQ
The E34 M5 FAQ
The E24 M6/M635CSi FAQ
de Witt is offline
Old 4th July 2007, 22:04   #13
SpecRaceM5
SpecRaceM5's Avatar
Garage: White '91 m5
Send a message via AIM to SpecRaceM5
I agree with the begining of your post, but the last part I felt was quote worthy! The more I think about it, the more I see how silly it would be. Yeah the glass is cool, but why let the sun in and block the wind out...
de Witt: I have often wondered this about other e32 parts. I honestly don't know the answer, but it brings up another quesition. Do the e32 door panles fit the e34?
I will have my headliner out to re-upholster it, so maybe when this happens I'll try the glass moonroof since I'm already half way there.
Cheers,
Brian
BMW STEP owns me.
SpecRaceM5 is offline
Old 5th July 2007, 11:06   #14
konst
Garage: M534T, M539, M330
Just too add my twopenceworths. I think those sunroofs were made by Webasto (certainly is on my m3), its possible that they may have produced something similar for someone else, out of glass.........
just a thought.
konst is offline
Old 5th July 2007, 19:26   #15
SpecRaceM5
SpecRaceM5's Avatar
That's what I'm thinking. Kind of a parts bin item.
Brian
Old 5th July 2007, 20:09   #16
Geach
Geach's Avatar
Garage: 1990 e34 M5 Sebring grey
I can sympatise with Ivan with the daunting task of fitting due to the fact that I had a hell of a job to get it all out,Bearing in mind I was also working on a scrapper! Although in my defence I did not refer to any literature.
Maybe I should have just chopped out a large square section of roof with the discsaw after all M8? At least you would of had a 'template' then?
Dan.
'90 M5- Sebring Grey
Geach is offline
Old 6th July 2007, 02:55   #17
BuickGSBoy
BuickGSBoy's Avatar
Garage: 1991 M5 Black
The mechanism is most certainly a Webasto roof, it has the logo on the motor.
My Uncle is a Webasto distributor in Pittsburgh. I have never spoken to him about this roof in particular, but speaking to him about others I do know that they only make a couple different sized chassis for the roofs.
I also know that replacing the glass panel is a fairly painless process as we replaced the panel in my Mom's Impala SS. Three screws per side. The M5 panel has these same screws as these are used to adjust how the panel fits in the roof when fully closed. (down slightly in the front, up slightly in the rear to minimize wind noise)
I do not know about the tracks for the sliding shade panel.
Kevin Poe
Savannah, GA
1991 M5
1972 Buick GS 350
1972 Honda CT90
1986 Buick Grand National (Totaled by my brother 12-26-04)
BuickGSBoy is offline
Privacy glass M5 CFF E34 M5 Discussion 16 15th August 2006 12:03
4 Season Moonroof vs. standard Moonroof ? DCN M5 E34 M5 Discussion 9 13th March 2006 15:12
Climate comfort glass turton E60 M5 and E61 M5 Touring Discussion 2 10th October 2005 22:06
Sunroof Glass Breakage KitchMD E39 M5 and E52 Z8 Discussion 2 9th March 2004 16:46
Liquid Glass Silverstreak E39 M5 and E52 Z8 Discussion 0 15th April 2003 16:09
Page generated in 0.16911 seconds with 11 queries
