An interesting quote here from a message in the E39 area...
"Most important, stay on this board so you can identify problem areas. The E34 can go boom due to the timing chain tensioner failing -- a relatively inexpensive part. If you know in advance, you can make sure that your tech is regularly inspecting weak points on the engine. "
Er Guys?
I didn`t know this was an issue. Is this common?
What mileage should this be examined/changed and what`s the expected cost for this preventative maintenance?
Does the engine have to come out, like when you would do a timing chain swap? Or is it something that can be done in situ?
What is involved? Is there a way to visually inspect it, or does a load of stuff have to be delicately removed and replaced exactly. (even thinking of messing with the timing gear gives me the eebee jeebees)
Arrghhh!! I won`t get any sleep now !!
