Old 3rd July 2007, 03:55   #1
GARedE34
GARedE34's Avatar
Garage: 2002 M3 Convertible - Silver
Engine shutting down while driving...
So I'm hoping someone can help me here. Twice in the last week while coming from 3rd gear to a stop in the right turn lane, (don't know if that has anything to do with it,) the engine has shut off and the steering gone dead. All electric stays on and both times I've turned the car back on and been on my way. My mechanic had a look today and all the belts are tight and the battery and alternator are providing good power.
Does anyone have any good ideas?
Possibly related, the power steering has gone numb and come right back, after 2 or 3 seconds, in corners. This hasn't happened in a while though, probably 3 or 4 months.
Thanks much for your thoughts!
GARedE34 is offline
Old 3rd July 2007, 10:32   #2
farrell
farrell's Avatar
Sales Feedback: (4)
Hi
Sounds fuel related.
There is a harness that supports power to the fuel pump & sls that exits out of the rear seat bulkhead.
Remove the seat & you will see where it exits.
Once it clears through the hole to the underneath of the car, you will notice that it gets very close to the rear suspension subframe.
The subframe can move a considerable amount.
This harness often chaffs & you get intermittant power to the fuel pump.
Engine cuts.
You pull over to the side of the ride.
Key on & off it goes again !
Very frustrating.
I would check visually for damage to wiring & solder a repair accordingly.
If its not this, then its likely to be bad earth or wiring of some kind.
You could also check the fuel pump relay but my money is on the first suggestion.
Cheers
Farrell
farrell is offline
Old 3rd July 2007, 21:06   #3
GARedE34
GARedE34's Avatar
Thanks Farrell! I'll check that out.
GARedE34 is offline
Old 3rd July 2007, 21:31   #4
ilovemy_e34
Garage: 1991 M5 Brillant Red
Just in case it is not the above problem, which is unlikely because vacuum lines on the brake booster seem to hold up well...
I once had the same problem and it turned out to be a split in the vacuum tube going from the intake to the brake booster. Though it happened to me on the freeway after everyone slammed on their brakes. The car drove home fine as long as I did not hit the brakes hard.
Another time I had that happened and it was the idler valve, but the car was idling horrifically besides shutting off -- it was sitting for two months. I am sure this is not your problem, but FYI once again.
-Cory
Even the wisest of doctors are relying on scientific truths, the errors of which will be recognized within a few years time. – Marcel Proust
ilovemy_e34 is offline
Old 3rd July 2007, 23:51   #5
ncaldiero
ncaldiero's Avatar
Garage: 1991 E34 M5 Jet Black/Dove Grey
I had a similar problem,
The wiring to the crank sensor had gone bad, refusing to send fuel to the engine, as it thought the crank wasn't moving...
good luck
Neil
I'd rather be judged by 12 than carried by 6.
1991 E34 M5 (current)
1989 E30 325is (sold)
2001 Jeep TJ Sport Lifted and Locked (sold)
ncaldiero is offline
Old 4th July 2007, 02:40   #6
The Bigfella
The Bigfella's Avatar
Garage: 1990 M5 White
I had a similar problem with my 500SEC Benz - it took months to find the piece of wiring harness that had a wire that was broken inside the insulation. I had another 500 at the time and I swapped a succession of parts trying to find the problem. Annoying, dangerous, inconvenient and even expensive. All tracked down to a small harness that I replaced for $10 in the end.
It sounds like Faz has put you on the right track though.
The Bigfella is offline
Old 4th July 2007, 04:37   #7
Sebring NL
Sebring NL's Avatar
Does your car have Servotronic?
Strange that the power steering goes off when the engine is running and the belts are tight.
Did this only happen since the intermittent engine fall-out?
The wiring harness is a classic failure rightly pointed out. Needs checking anyways.
Fuel filter might be worth looking at too.
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
Old 4th July 2007, 10:18   #8
SpecRaceM5
SpecRaceM5's Avatar
Garage: White '91 m5
Send a message via AIM to SpecRaceM5
My experiences with this sort of problem have been due to vacuum leaks, ICV, or adjusting ECU. The vacuum leaks and ICV I'm sure you are familiar with already. The adjusting ECU as I call it, was due to a bad battery connecting. It's a long story, but when ever I would reconnect the battery and drive the car before the ECU had a full hold on things, I would some times stumble at idle and even stall. Other then that I don't know. I have heard interesting stories with fuel pumps going bad and being very hard to troubleshoot. That's probably not the case, but until you figure it out it really could be anything.
Brian
BMW STEP owns me.
SpecRaceM5 is offline
Old 4th July 2007, 15:12   #9
The Bigfella
I used to have that propblem before my rebuild - it was due to the bypasses in the inlet being clogged up.
Old 4th July 2007, 20:03   #10
SpecRaceM5
SpecRaceM5's Avatar
Good to know! I'll be sure to check this when I do my rebuild.
Brian
Specifications of every BMW Der Abt Off Topic Forum 10 7th June 2008 15:16
BMW M6 Convertible Press Release 2: Chassis and suspension (in English and German) Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 1 23rd June 2006 00:05
BMW M6 Press Release no 1: World Debut of the new BMW M6 (short version). Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 4th January 2005 20:39
SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 02:42
Page generated in 0.16072 seconds with 11 queries
