Old 27th June 2007, 22:54   #1
Sebring NL
Sebring NL's Avatar
Getting my hands dirty on E34 M5!!
Wasn't mine though, member RacerZ had some SLS trouble :
It appeared that the actual attachment of the actuator for the SLS had torn out of the chassis! Problem was that my mechanic decided against welding in that area, as its thin material and the risk of causing a fire or extreme heat in the section under the rear seat where all the electronics are would be too dangerous. Also, the foam that settles between the two layers of sheet metal could catch fire and cause trouble. So , we riveted/bonded a new carrier in the repaired chassis part,
We had to take the exhaust off in order to access the problem, which resulted in the flanges breaking. The ones that could be ordered would come in too late ( car had to be finished today, parts would arrive next week!) and some of them can't be separated from the exhaust. That's why my mechanic copper-welded them back together again:
Since I had some time left before dropping off the car, I decided to do some minor things that caught my eye ( can't be helped!! its an M5!!)
Sunroof had gone a bit flat, so that polished up nicely:
Took the wipers off as they had lost a lot of paint:
After rough-primering to get the OEM effect, they looked a lot better:
Nicked a badge off an old scrap E30 we had standing around..Not new, but better :
God is in details
Ended up polishing the car from the rubber strips upwards:
Good to work on E34 M5's again..Now to get that Sebring out of the garage
Wout
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
Old 27th June 2007, 23:26   #2
hertfordshire1
hertfordshire1's Avatar
Garage: BMW M5 e34
Wout,
I think you need a trip over here to work your magic on my car fella....
Steve
"If it breaks again.................. I give up."
hertfordshire1 is offline
Old 27th June 2007, 23:37   #3
Sebring NL
Sebring NL's Avatar
I hope FFS that of all cars, yours is NEW by now mate
Old 28th June 2007, 00:57   #4
davidoli
Excellent stuff Wout ......it's all in the detail my friend !
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 28th June 2007, 02:01   #5
illjah
Garage: 1995 M5 LE40/50 Orinico Green
i really like that touring! was nearly mine b4 the LE, so its thanks to me that ones still on the road!!!
illjah is offline
Old 28th June 2007, 02:32   #6
Sebring NL
Sebring NL's Avatar
Yeah I remember you telling us that.
Its a great car. E34's have sooo much more soul than new cars. The way the car just shrinks around you when you drive it..Plain at home! Actually, it was quite a while since I drove an M5 Touring The sound of idling an S38..Never rivalled
Old 28th June 2007, 12:44   #7
Jahangeer
Jahangeer's Avatar
Garage: .................
Wout you have unflappable energy, good post too.
What did you paint the windscreen wipers with after sanding?
Regards
J
Jahangeer is offline
Old 28th June 2007, 12:46   #8
Sebring NL
Sebring NL's Avatar
I have a special "rough surface primer" which replicates the OEM finish. After that, simple 2-component flat black paint with a little bit of lacquer in the hardener so it doesn't become as flat as rubber.
Wout
///M5HD91-229-
///M535iDC71-181-
|H&R|Bilstein|Sparco
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
740d GE81-317-
Old 28th June 2007, 13:15   #9
hertfordshire1
Garage: BMW M5 e34
I wish mate!
Its off to be repaired AGAIN!!!!
I think its time I updated my signature?
Steve
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 01:11
M5 / E55 comparison -after owning each- LONG Scott in Houston E60 M5 and E61 M5 Touring Discussion 34 12th April 2007 01:39
E34 M5 owners in midwest United States? flipwils11 E34 M5 Discussion 3 22nd January 2005 04:35
Page generated in 0.18062 seconds with 11 queries
