Old 27th June 2007, 20:59   #1
Rob Plummer
Garage: E34 M5
The Nordschliefe ate my bushes
These were brand new, zero miles when we set off...........
Rob Plummer is offline
Old 27th June 2007, 21:16   #2
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
Were they the standard M5 ones or the 750i ones?
2005 E60 M5 Interlagos blue
yewcorner is offline
Old 27th June 2007, 21:27   #3
Rob Plummer
Garage: E34 M5
Standard ones from GSF.
Will butcher them out and put the Powerflex ones in that I've got kicking around the garage......
Moral of the story is to only buy genuine BMW parts..................
Old 27th June 2007, 21:42   #4
konst
Garage: M534T, M539, M330
where tehy original BMW or someone elses?
what made you check?
konst is offline
Old 27th June 2007, 22:36   #5
farrell
farrell's Avatar
Sales Feedback: (4)
Rob
They look like inner bushes on the lower wishbone or rod
Were those bushes fitted with the stub axle supported ?
Was the bolt put through the bush assembly & tightened whilst there was no weight of the hub assembly pulling down on the bushes ?
What you have shown is symptomatic of this.
http://www.realoem.com/bmw/showparts...50&hg=31&fg=05
Farrell
farrell is offline
Old 27th June 2007, 23:29   #6
Rob Plummer
Garage: E34 M5
They weren't BMW Konst. Checked because of a rattle which developed on the way home...............
Old 27th June 2007, 23:31   #7
Rob Plummer
Garage: E34 M5
Originally Posted by farrell View Post
Rob
Farrell
Yeah - it's the rear bottom arm. I Admit I didn't have something taking the weight of the strut etc while tightening up the bolt, but then I tightened it again once the car was back on its wheels..........
Did I cock it up?
Old 28th June 2007, 00:13   #8
farrell
farrell's Avatar
Sales Feedback: (4)
Hi Rob
Sorry, but it does look like you possibly did.
You should not load the bushes with any kind of vertical downward mass until the bushes are tightened & the vehicle lowered back to the ground.
Most use a bottle jack or similar to support the hub until all is tightened & back in place.
Farrell
farrell is offline
Old 28th June 2007, 00:20   #9
Rob Plummer
Garage: E34 M5
Hi Rob
Farrell
ooops!
So I should have only tightened them up slightly with something supporting the weight of the strut and then REALLY tightened them once I got it back on its wheels?
Luckily, I've still got the Powerflex bushes, so I'll bung those in - following the correct procedure this time!!!
Old 28th June 2007, 00:50   #10
davidoli
As an afterthought , I've always found those Lemforder arms from GSF to be a quality part .....
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
London; Experience in checking bushes & sway brackets stumbo E39 M5 and E52 Z8 Discussion 2 11th June 2007 01:54
Handling after fitting Powerflex bushes JED E34 M5 Discussion 6 10th April 2007 03:48
Replacing Rear Suspension Bushes jrobbo E34 M5 Discussion 4 30th March 2007 14:29
Lower Tie Bar Powerflex Bushes noMi5 E34 M5 Discussion 11 24th August 2006 14:02
Uprated Upper Control Arm Bushes AndyE E34 M5 Discussion 2 16th December 2004 09:53
Page generated in 0.14226 seconds with 12 queries
