Old 26th June 2007, 14:29   #1
shuggy47
shuggy47's Avatar
Garage: 93 E34 M5 3.8 Avus Blue
Removal & Fitting Coding Plug
I have recently been having problems with my gauges which i thought i had fixed by replacing the capacitors - no such luck.
I have managed to get my hands on a similar set of guages from a non M5 E34 which means the revs/MPH and oil temp gauges are different however believe that changing the coding plug with my M5 one will fix this.
So to my actual question how do i remove and fit the coding plug on my guages (blue plastic rear with plug attached) and will it work ie different RPM/MPH reading (i will obviously change the backgrounds over as well).
Cheers
shuggy47 is offline
Old 26th June 2007, 23:12   #2
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
Alright Al, Have you checked the wiring loom where it passes over the rear subframe?? I know Farrell and Alan Archer (iirc) have had some problems there before. Have you tried removing and checking all you relays make sure you have no corroded terminals ??
Changing the gauges seems a bit extreme, are the gauges known to be faulty?
Phil.
Phlem5 is offline
Old 27th June 2007, 11:32   #3
shuggy47
shuggy47's Avatar
Phil i took my gauges out and checked the circuit board and one of the capacitors has blown - but turns out the guy that changed them over for me didn't use a high temp capacitor.
However i've took the circuit board off the non-M5 set (looks exactly the same) and put that on my M5 gauges whilst also changing the coding pin over - not a big job. So will try putting the new assembly in today and see how things go - fingers crossed.
shuggy47 is offline
Old 27th June 2007, 18:21   #4
shuggy47
shuggy47's Avatar
Put the gauges back, everything looks good except some of the bulbs are out on the left hand side so will take out again and replace with the bulbs from my old unit tonight and check that all is well.
I must say having wonky gauges is a real pain in the ar$e.
If this does work, i certainly can't complain at £25 for the new gauges from a 535 Touring from a scrappy instead of the £135 for M5 ones that i've seen on ebay.
shuggy47 is offline
Old 27th June 2007, 18:39   #5
Phlem5
As long as the M is still in the binnacle evrything should be cool ! Got say, I cant think of hearing about this kind of problem before Alan, weird. Maybe explains why there's not been a torrent of helpful replies, either that or there's a thread of nonsense - possibly wheel related that is of greater technical interest / use to the forum........
Phil.
Phlem5 is offline
Code plug removal tool D_C_R E34 M5 Discussion 1 18th April 2007 13:06
Bumper Plug Removal for E60 525i? PlatinumM6 GTBoard.com: General Sportscars 2 21st February 2007 07:43
Diagnostic Plug Question London Mike E34 M5 Discussion 3 16th October 2006 01:15
Coding Plug - Where to get one D_C_R E34 M5 Discussion 0 2nd November 2005 09:50
M5 rear deck removal for stereo upgrade (pics!) sysvr4 E39 M5 and E52 Z8 Discussion 1 9th July 2002 00:54
Page generated in 0.81700 seconds with 11 queries
