Old 19th June 2007, 18:20   #1
Mmm-Five
3.6 Air Con
This might be a silly question, but shouldn't there be a fan in front of the air con condensor as well as the viscous fan behind the normal radiator.
I only ask as I've just had a new condensor fitted and we noted there was no air con fan as I had on my 3.8 - I just assumed the 3.6 would have one as well, but am prepared to be re-educated on the matter.
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Old 19th June 2007, 19:09   #2
farrell
farrell's Avatar
Sales Feedback: (4)
Hi m8
Electric fan in front of A/C condensor & water cooling radiator pack.
You must have this fan operational as its for main engine cooling as well as condensor.
The clutch viscous fan driven off the engine is for moving underhood engine heat & preventing
localised hot spots.
Sounds very strange m8.
Cheers
Faz
farrell is offline
Old 19th June 2007, 19:22   #3
Mmm-Five
Looks like that's another bit I need then - although the water temp does sit nicely at just below half-way most of the time.
Item #3 on this diagram I guess...
http://www.realoem.com/bmw/showparts...32&hg=64&fg=55
Will this mean I've got to take the radiator & condensor out (and drain/refill everything) again? And is it a BMW only part or will GSF/ECP do one as I see it's common to lots of models - or would an aftermarket motorsport one suffice?
And to think, I wasn't going to bother getting the aircon done. I just thought that as everything else was done I would do this final piece - silly me, I should have known what tricks M5s get up to by now.
Mmm-Five is offline
Old 19th June 2007, 19:49   #4
farrell
farrell's Avatar
Sales Feedback: (4)
Hi
Use GSF or ECP part.
I think its o/e anyway.
Don't recommend a motorsport item.
Stay with factory cooling calibration.
I think you may have better luck removing the bumper & grill to address the electric fan & shroud assembly assuming that you do not want to remove the cooling packs & refill.
Cheers
Farrell
farrell is offline
Old 21st June 2007, 00:39   #5
nexus1972
Garage: E34 M5 Sebring Grey 1991
Originally Posted by farrell View Post
Hi
Cheers
Farrell
If ur after a s/hand item I found one off a 7 series was a perfect fit.
nexus1972 is offline
Old 21st June 2007, 01:47   #6
scotchw
scotchw's Avatar
Garage: Calypso Red 3.6 M5
PO replaced this part on my car last summer. £130+VAT from ECP. They commonly fail (seize up) due to exposed location & lack of use. PO only discovered it was broken when using A/C in really hot weather whilst stuck in traffic jam & noticed engine temp gauge climbing (went back down when A/C switched off again!).
You don't want to cook an M5 engine I'd go for a new part for peace of mind.
scotchw is offline
Old 21st June 2007, 02:37   #7
jonsmiff
jonsmiff's Avatar
Garage: e39 m5 silverstone blue
i got 1 off a 525 td,same part
jonsmiff is offline
Single Din to replace central air con vents crnjyM5 E39 M5 and E52 Z8 Discussion 10 16th December 2006 04:14
BMW M6 Press Release no 5: Body, Design, Equipment: Light and Safe, Sporting and... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 15th December 2004 22:25
24 degress less intake air temp Pete E39 M5 and E52 Z8 Discussion 35 5th July 2004 05:49
rpm / air con sdc77 E34 M5 Discussion 3 5th April 2003 00:22
Page generated in 0.12683 seconds with 11 queries
