Old 19th June 2007, 13:29   #1
jrobbo
jrobbo's Avatar
Garage: BMW E34 M5 Macau Blue
Badge Template?
Hey guys,
I know that this has been asked before, but I couldn't find the answer anywhere. Does anyone have the template for the correct position of the M5 badge on the boot (trunk) lid please? I really did search as I know it's been posted here before, but could only find mention of the E39 M5 badge.
John
My E34 M5: http://www.jrobbo.com/M5
License Plate: "EUROM5", VIN: "GA25294". Come and get me!
jrobbo is offline
Old 19th June 2007, 13:52   #2
dronfieldm
Garage: 1995 BMW M5 3.8 6 Speed - Avus Blue
Bottom right corner of the 5 is 27mm in and 24mm up from the edge of the bootlid.
The M obviously goes to suit......prob best doing by eye after........
Hope this helps a bit........
Mark
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline
Old 19th June 2007, 13:55   #3
dronfieldm
Zooming into the attached pic might help more....
Old 19th June 2007, 17:43   #4
DrSakke
DrSakke's Avatar
Mark
Hi!!
I think you got it wrong there.....
should be :
- from the bottom lip of the trunk = 16mm
- from right edge of trunk to outside of the "5" = 26mm
- gap between the "M" and the "5" = 8mm
The E30 M3 shop manual specifies a gap of 9mm between the M and the 3, so it's pretty safe to conclude that a gap range of 8 - 10mm is the correct range for the gap between the emblems. I'm going to redo mine at 16mm bottom, 26mm side, and 9mm gap in-between.
http://www.bmwe34m5.com/node/31
Sakke
DrSakke is offline
Old 19th June 2007, 22:50   #5
dronfieldm
Ah right........had measured mine with a ruler in the garage, looks like its OK horizontally then but too high.
Was like that when I bought it..........
Looks like we have certified measurements.
Mark
Old 20th June 2007, 04:07   #6
The Bigfella
The Bigfella's Avatar
Garage: 1990 M5 White
Hey John - they look great if you put them on at an angle
........ just joking mate!
The Bigfella is offline
No m5 badge vs Yes to m5 badge Poyan E39 M5 and E52 Z8 Discussion 28 27th December 2006 01:05
Side Molding with M5 badge billrM5 E39 M5 and E52 Z8 Discussion 11 8th March 2005 18:55
Rulers please! Euro M5 badge location GDA E34 M5 Discussion 4 31st August 2002 12:39
DINAN badge: Alternative mounting locations? Cerberus E39 M5 and E52 Z8 Discussion 20 19th April 2002 19:10
To Dinan badge or not to Dinan badge?? lrattner E39 M5 and E52 Z8 Discussion 15 16th November 2001 20:41
Page generated in 0.11450 seconds with 12 queries
