mmm... I `ve just been looking at the picture I posted from my car with the turbines off at the moment.
Is is possible to fit the 345mm floating disk brakes (front) with 4 piston calipers and 328mm disks (rear) from the later 3.8 cars to the earlier 3.6 and 3.8 ??
For example, if I bought a car that had been chasing trees, could I take the entire rotor and caliper system straight off and bolt it on, or are there problems?
If the floating disks would be troublesome to get fitted, what would be the approximate cost (£ sterling UK if possible) to add some larger rotors, as I understand from previous posts that the 345mm disks will definately fit inside the standard 17" rims the car is supplied with.
If I didn`t go with this, what are your expert opinions on the subject of removing the fog lights and fabricating ducts to provide additional cooling?
I understand the disc cover needs to come off, and grooved and/or drilled brake discs must be installed to counteract the fact that there is now no protection from water buildup.
Would this be enough "extra" to compensate for the lesser brakes on the 3.6 when driven hard, track days etc etc.?
