Old 27th September 2001, 23:22   #1
ydelta
ydelta's Avatar
Garage: Citroen 2CV with a NOS kit
Oil quantity ?
Well, I'm about to make the oil change myself (what a challenge isn't it ?) but I am still unsure about the capacity of the oil tank : I've read from various sources different figures (6.5 to 8 liters) so I want to make sure that I will fill it correctly (I bought 8 liters of Mobil 1 5W-50 so I think I'm safe).
I'll change the oil filter so any advices are welcome if it is not as straightforward as it looks like
Y@nn
ydelta is offline
Old 27th September 2001, 23:59   #2
mikek
Garage: 530i
oil
Hi there,
My 3.6 engine takes 5.0 litres for an oil change without changing the filter, and 5.75 litres when changine the oil and filter.
ie. the filter holds about 0.75 litres.
P.s Mobil 1 5/50 is too thin for your engine!!! It will be as rattly as hell!! I just put mobil 1 10/50 in mine and have changed it after 1000 miles to castrol magnatec for advanced engines. It now sounds quiet!!
Regards Mike K
mikek is offline
Old 28th September 2001, 00:08   #3
IvanDias
IvanDias's Avatar
Hi to mikek
I have changed from unknown to Castrol GTX Magnated 10sw40 and my engine is now noisier, rattley and tinnier sounding. How come yours got quieter?
I put my noise increase down to an impeding Inspection II due.
What is the official line from BMW on oil weight, and what is recommended to keep the noise down, as mine has 80000 miles on it.
PS. Which way around does the oil number work?
In 10sw40, is 10 the thinnest when hot, ie 0sw is thinner when hot....
...and 40 liquid when cold, ie 50sw liquid when 40 would not run as well in very cold climates, eg Sweden etc?
Or have I got it the wrong way around ?
Ivan.
E34 ///M5 3.6 1990
IvanDias is offline
Old 28th September 2001, 16:27   #4
ydelta
ydelta's Avatar
Re: oil
Mikek, thanks for the info on oil capacity.
Originally posted by mikek
Hi there,
Regards Mike K
I don't think so, I have already Mobil in my car and it is not noisy or rattly (or if it can be quieter, I cannot figure out what would be the noise The only 'rattle' I have is the normal tiny rattle of the clutch when the pedal is up.
Regarding the oil brand, I would love to put Castrol RS10w60 but I cannot find it here in France. I was told that the second best choice for the E34 M5 was precisely Mobil 1. Any opinion from Mobil 1 users here before I commit the irreparable ?
Y@nn
ydelta is offline
Old 28th September 2001, 17:14   #5
momo5
Garage: E34 M5 3.8 5 speed
Hi to Ivan,
Wrong way around the oil specification; First smaller figure means the lowest temperature in wintertime usage. The larger second figure is, the tougher in high revolution usage is possible; for example, race usage.
So 5W-40 oil is easier for cranking at wintertime than 15W-40. 5W-60 is much better performance in 6000-7000 RPM running than 5W-40.
Friends of mine (42 E34 M5s in a group, which is totally around 200 E34 models including Alpina B10 and its Bi-turbo!) are recommending RED LINE brand oil that I believe made in Italy or Germany.
momo5 is offline
Old 28th September 2001, 20:38   #6
M5 powered
Garage: M5 limited edition (02/50) Rosso Red
Hi everyone. As for the official line on what oil to use in the E34 by BMW UK, one of the few approved is Castrol SLX 0w30 which at first I thought was too thin for the engine, apparently not! BMW recommended it as it has enhanced anti sludge and warm up proporties over the magnatec stuff and is proven to be a better protector @ high engines revs on older performance engines. Not taking the hype at face value from BMW, I did find an independent web site which tested performance oils in europe, concurring that SLX was better for the older performance car. Will post address when I remember it!
The only problem with using SLX is it's like hens teeth to find in the UK, taking me two weeks to track some down!
On the issue of noise, having compared my 3.8 with my mates (both 1995 E34's that have covered 80K and BMW serviced from new) there is no audible difference between my car and his running standard castrol magnatec oil.
For what it's worth
M5 powered
M5 powered is offline
Old 2nd October 2001, 21:30   #7
roger_aspequist
Garage: BMW M5 1995 Avus blue
How about Quakerstate oil?
Roger
roger_aspequist is offline
Old 3rd October 2001, 00:01   #8
raymondw
raymondw's Avatar
Hello Yann, Momo5,
The S38 engine contains 6.5 litres of oil of which about 0.5 litre in the oil filter.
When the E34 ///M5 was introduced in 1988, BMW specifically prescribed the use of Wintershall 15W40 oil. On my car the sticker in the engine bay which mentiones this is still present. Also in the manual, this oil brand and type is mentioned. The manual also prohibits the use of light friction oil types.
Now 13 years later, the quality of the oils have been improved and there are more very good alternatives. But with oil selection you have to take some points into consideration.
The internal construction of the S38 is such that low weight oil types (0W40, 5W40) does not have any benefit's. It is true that at operating temperature, there is not much difference between 5W40 and 10W40, but at cold start and while warming up, the thin oil types won't lubraicate the piston walls sufficiently due to the higher tolerances from piston to piston wall.
In 1999, my dealer accidentally used Shell Helix 5W40 for my E34 ///M5. After this change, my engine did not run as smooth as with the previous Mobil1 10W40. When warmed up, my engine ran frictionous and sounded somehow metallic. Besides, an oil leak started from the chain guide bolts on the timing cover. After 2500km, I ditched the Shell oil for the Castrol RS 10W60 and after this oil chance, my M5's engine was running great again. The frictionous running had disappeared and reving up ecame a real pleasure again.
If Castrol RS 10W60 (which I still use and can highly recommend) is unavailable, then the best alternative is Mobil1 10W40. In any case do not go below that grade. Thin oil types are develloped primarily for modern engines with their very low mechanical tolerances, but not for older design engines like the S38.
With best regards,
Raymond
1990 E34 ///M5 3.6
1985 E28 ///M5 3.5 (without cat)
raymondw is offline
Old 3rd October 2001, 04:49   #9
ydelta
ydelta's Avatar
Hello Raymond,
Thanks for your enlightenment. However, under my bonnet there's a sticker which indicates to use the Castrol 'magnatec' 5W40... so I assumed I could go below 10 for the cold grade viscosity. Furthermore the previous owner put Mobil 5W50 and the car runs great (at least it seems to but maybe the engine could run smoother but I can't figure out)
I will check but I didn't notice a Mobil branded oil with 10W40 grade. Maybe it is not imported here :-(
There's so much choice : what about Elf Competition oil for instance ?
Y@nn
ydelta is offline
Old 3rd October 2001, 08:30   #10
raymondw
raymondw's Avatar
Hello Yann,
Cannot comment on Elf oils since I have never used it, but I have had some bad experiences with Elf fuel on more occasions when I was in the French Alps in summer 1999 and in Switzerland in spring 2000.
That aside, I cannot give comments about Elf lubrication products, since I have never used them.
With best regards,
Raymond
raymondw is offline
Peter Pan BMW -- bad service, No 1200 mile oil change on 03 jdh E39 M5 and E52 Z8 Discussion 29 21st May 2004 17:49
Oil Analysis...Recommended more frequent oil changes drallen E39 M5 and E52 Z8 Discussion 40 8th September 2003 22:10
too much oil after oil change.... Brother Methias E39 M5 and E52 Z8 Discussion 19 27th May 2003 19:00
Checking oil, back to basics? kwalls E39 M5 and E52 Z8 Discussion 25 29th April 2003 02:04
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.15877 seconds with 11 queries
