Old 24th September 2001, 17:45   #1
M5 powered
Garage: M5 limited edition (02/50) Rosso Red
What Oil?
The low oil level light has just come on and I'm wondering which oil to get. The BMW garage used Castrol slx on it's last service about 7000 miles ago. Is this stuff good enough not to thin etc. etc. or does anyone recommend another? I know you aren't suppose to mix them!
Thanks in Advance
M5 powereed
M5 powered is offline
Old 24th September 2001, 23:43   #2
IvanDias
IvanDias's Avatar
Oil
hi,
I suspect a lot of replies to this post will be forthcoming.
My two pence is
Castrol GTX Magnatec in 10sw40.
I wanted Mobil 1 in this weight, but can only find 0sw, which I understand can be too thin and leak in older (50000+miles) engines.
I have noticed more noise over the last two months (500miles ish) but as I am due a Inspection II and valve adjustments I am putting it down to the shims and clearanaces, not the oil.
I am new to ///M5 so will be looking at all replies with an open mind, so if I ought to be using something else, then please tell me.
Ivan
E34 ///M5 1990 3.6 80000mls
PS. Dont drive it with that light always on. Action is required !!
IvanDias is offline
Old 25th September 2001, 08:38   #3
WylM5
WylM5's Avatar
Garage: 91 E34M5 01E39M5
Exclamation
7,000 miles? Never mind adding oil, it is time to do a complete change of filter and oil.
I'm not sure what "Castro six" is in your statement but even if it is a full synthetic I believe you are due a complete change. And as far as just topping up I would go with whatever brand your shop is using. I keep an extra quart in a ziplock bag in the trunk along with a liter of water and some good old duct tape. (duct tape can fix anything)
WylM5
WylM5 is offline
Old 25th September 2001, 14:35   #4
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
I was told too that Mobile 1 is too thin for the engine...
I was recomended Castrol Magnatec for advanced engines by Munich legends, who rebuild the babies !
I must admit when running it on Mobile 1 it was rattly as you like !
Also...you should check your oil WEEKLY !!
you have a ten grand engine !!!
Alan Archer.
Alan Archer is offline
Old 25th September 2001, 22:28   #5
Bryn
Garage: BMW M5, Black, 1993, 3.8
Millers 10w/40 has been recommended to me by the guy with the worlds fastest road car (guiness world record!).
Must be OK stuff!
Bryn.
Bryn is offline
Old 26th September 2001, 00:10   #6
NRL BITURBO
Garage: Alpina B10 Bi-Turbo Alpina Blau Metallic
Re: What Oil?
... Castrol RS Syntec 10/60 ... great stuff & I use it in my Alpina B10 Bi-Turbo (Alpina recommended).
Neil
NRL BITURBO is offline
Old 26th September 2001, 02:36   #7
KKelly
KKelly's Avatar
Garage: 91 M5 Alpine White
Most of us Yanks use Mobil 1 15/50. I tried a 10/40 once and was using a lot more oil (Redline).
Kevin Kelly
91 M5 Alpine White/Black
(D'Sylva Chip, Dinan springs w/Konis, camber plates
Racing Dynamics sway bars, 18" BBS RC's
345mm brakes)
'95 M3 Avus/Dove, (Conforti CAI/software, 24lb inj., GC suspension), new track rat.
KKelly is offline
Old 4th January 2002, 07:18   #8
MMORTAL
MMORTAL's Avatar
Garage: 2002 M5 Carbon/Caramel
Castrol TWS Motorsport 10W60?
Just had my 1200 mile service and BMW dealer says that Castrol TWS Motorsport 10W-60 is the newest for the M5. Anyone heard of or using this? Critiques/
Thanks!
Phil
2002 Carbon/Caramel
MMORTAL is offline
Old 4th January 2002, 07:52   #9
de Witt
de Witt's Avatar
Garage: 1988 M5 (x2) 1991 M5 2008 M5
Send a message via AIM to de Witt
Are you talking about the e34 or e39 M5?
I noticed you have an e39 and BMW switched oils to Castrol Syntec 10w60 for the e39. Do a search in the "e39 M5 and Z8 forum" and you will find a slew of threads with much more detailed information
In the e34, as Ivan and Alan said, Castrol 10w40 is generally recommended by BMW. I used Castrol 10w40 GTX on my old e34, and I found it used a quart between each interval, but I topped it when it was low and had no problems at all with leaks.
{o,o}
|)__)
The E28 M5 FAQ
The E34 M5 FAQ
The E24 M6/M635CSi FAQ
de Witt is offline
Old 4th January 2002, 07:53   #10
Calgary3.6
Calgary3.6's Avatar
Garage: 1991 M5 3.6 Black/black
I'm using Redline 10W40 with changes every January (2002 will be my first actual Redline change, but I digress...).
I've only conusmed about 300ml over the last year and 14,000kms. Yes, I treat the engine gently until 60-70C oil temp, but then lookout! Redline in the crank case, Redline on the tach.
I'd put Mobil 1 15W50 in for 2 weeks prior to the Redline and the car felt like it was pulling a small trailer. The extra viscosity really sapped some power and the upper RPM range was much weaker. The Redline woke it up again, though!
Some have said the S38B36 is prone to noise if too light an oil is used. I've not noticed it at all.
Fuel consumption hovers at 14L/100 city (moderate traffic but low average speeds) and I got 9L/100 on a 2500km highway trip in October (averaged 90km/h).
Cheers,
Anthony
A Freudian slip is where you say one thing and you mean your mother.
Calgary3.6 is offline
Oil Analysis...Recommended more frequent oil changes drallen E39 M5 and E52 Z8 Discussion 40 8th September 2003 22:10
too much oil after oil change.... Brother Methias E39 M5 and E52 Z8 Discussion 19 27th May 2003 19:00
Checking oil, back to basics? kwalls E39 M5 and E52 Z8 Discussion 25 29th April 2003 02:04
Oil level = oil temp? ALX E39 M5 and E52 Z8 Discussion 15 17th January 2002 02:46
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.15237 seconds with 11 queries
