Old 4th January 2002, 08:01   #11
de Witt
de Witt's Avatar
Garage: 1988 M5 (x2) 1991 M5 2008 M5
Send a message via AIM to de Witt
Originally posted by Calgary3.6
I'm using Redline 10W40 with changes every January (2002 will be my first actual Redline change, but I digress...).
I've only conusmed about 300ml over the last year and 14,000kms. Yes, I treat the engine gently until 60-70C oil temp, but then lookout! Redline in the crank case, Redline on the tach.
What sort of oil change interval are you calculating with the Redline? Any problems with leaks? Sounds like you are happy with it!
{o,o}
|)__)
The E28 M5 FAQ
The E34 M5 FAQ
The E24 M6/M635CSi FAQ
de Witt is offline
Old 4th January 2002, 08:15   #12
Calgary3.6
Garage: 2007 Infiniti G35x
My annual milage/kilometerage is 18-20,000kms. Redline suggests the interval can be up to 20,000 miles (30,000km). I do change the filter as a precaution in late August - usually prior to our annual long road trip. The oil is due for a change now, and it is still just a nice dark brown colour.
I have no real leaks to speak of. Admittedly, the block and oil pan are damp, though. I do have a bad "o" ring where the oil drains from the head to the block (under #6 header pipe). This "o" ring will be changed next week.
Changing the topic a bit:
If I open the oil cap whilst the engine is idling, no change is evident. Both my '88 325is and my '90 535 would react to this air leak by increasing the idle 2-300rpm then running rough with misses and sputters. Shouldn't the M5 do this also?? Can anybody confirm or check and advise??
Thanks,
Anthony
A Freudian slip is where you say one thing and you mean your mother.
Calgary3.6 is offline
Old 4th January 2002, 08:23   #13
de Witt
de Witt's Avatar
Thanks,
Anthony
Hmmm, possibly the S38 is able to adjust quicker/better for the increase in air by decreasing the amout taken in. I have never done this, though if it sputters and misses (even on an M20 engine) I would not advise it (especially on the S38!)
de Witt is offline
Old 5th January 2002, 02:54   #14
Calgary3.6
Perhaps I should clarify -
Exchange "sputter and miss" to "stumble and waver". The effect is really not as extreme as to cause worry about damaging anything.
On the M20 and M30, the check engine light would also come on after a few (say 5 or 6) seconds of running with the cap off.
There has to be somebody sufficiently adventurous to give it a try and let me know!
Thanks,
Anthony
Old 5th January 2002, 16:31   #15
mikek
Garage: 530i
I find mine runs well on Castrol Magnatec.
Regards
Mike K
mikek is offline
Old 5th January 2002, 23:24   #16
Bryn
Garage: BMW M5, Black, 1993, 3.8
I have Shell Helix in mine now. Runs great, no complaints so far. Don't know what weight unfortunately.
Bryn.
Bryn is offline
Old 5th January 2002, 23:59   #17
mikek
Garage: 530i
Bryn,
Is helix fully synthetic??and how much is it???
regards
Mike k
mikek is offline
Old 6th January 2002, 17:52   #18
Bryn
Mike,
I believe its fully synthetic, but I am not certain. You can get it from Shell garages though, so might be worth having a look there.
Bryn.
Bryn is offline
Old 6th January 2002, 22:25   #19
klunk
klunk's Avatar
Garage: 1992 3.6, Calypso Red, Half Leather/M-Fleck
i run mine od 10w40 Magnatec, after advice from Munich Legends,
even apart from oil leaks, they said the chain tensioner requires this weight of oil to operate correctly.
it is my understanding that only cars with hydraulic lifters need thin oil, ie 5w, or 0w, in order to pump the lifters up quickly and efficiently at high rpm,
i used to run a kawasaki zx6r, which ran on 10w40 semi sythetic oil, as it used mechanical lifters, the same as the s38.
this is despite the engine redlining at 14500rpm.
correct me if i'm wrong.
klunk
klunk is offline
Old 14th January 2002, 23:09   #20
Marek
Garage: 1991 E34 M5 - Burgundy
What Oil
I use Amsoil 20w-50 in all my vehicles (M5 and SL500). I used to use Motul 300 synthetic 15W-50 which I liked a lot but it was too expensive.
http://www.oil-tech.com/ser20w50.htm
http://www.oil-tech.com/amscmpr.htm
Marek
Marek is offline
Oil Analysis...Recommended more frequent oil changes drallen E39 M5 and E52 Z8 Discussion 40 8th September 2003 22:10
too much oil after oil change.... Brother Methias E39 M5 and E52 Z8 Discussion 19 27th May 2003 19:00
Checking oil, back to basics? kwalls E39 M5 and E52 Z8 Discussion 25 29th April 2003 02:04
Oil level = oil temp? ALX E39 M5 and E52 Z8 Discussion 15 17th January 2002 02:46
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.15589 seconds with 11 queries
