Old 15th January 2007, 17:17   #1
ajinfante
ajinfante's Avatar
Garage: DiamondSchwarz 1990 M5 Euro
v-belts
Is there a location online that has the procedures for replacing the v-belts? My alternator belt shredded yesterday (luckily only a mile from home), and I figured I'd go ahead and replace them all.
How long would it typically take a home-mechanic to replace all three belts?
Thanks,
Andy
ajinfante is offline
Old 15th January 2007, 17:47   #2
AlexA
AlexA's Avatar
Garage: 92 E34 M5 Touring Diamond Black
A couple of hours max. Make sure you don't overtighten them.
regards
Alex
AlexA is offline
Old 15th January 2007, 17:59   #3
ajinfante
ajinfante's Avatar
Should I be worried about something else that caused the belt to shred? The waterpump was replaced 5 years ago - about 45k miles ago. Should I replace that? How can I tell if waterpump is working or not?
What's the procedure for getting the fan off and the rest of the belts?
Old 15th January 2007, 18:05   #4
ajinfante
ajinfante's Avatar
Also, all three drive belts were replaced 30k miles ago...what am I looking at here?
Old 15th January 2007, 18:28   #5
AlexA
AlexA's Avatar
Squeeze the fan belt together to prevent the fan from slipping and undo the 32 mm nut. Remember it has a left hand thread. The water pump I would check for play or signs of leaks. Overtightening the belts will cause quicker bearing failures . A lot of mechanics tighten the belts too much.
AlexA is offline
Old 15th January 2007, 18:32   #6
AlexA
AlexA's Avatar
They are supposed to be changed every inspection 2 (or was it 1?). I would change mine at 30K or less considering they cost next to nothing and are easy to change. Don't know why yours broke though.
AlexA is offline
Old 15th January 2007, 18:39   #7
ajinfante
ajinfante's Avatar
how do the other belts get loosened? I don't have a fan belt anymore, remember? ;-)
Old 15th January 2007, 18:53   #8
AlexA
AlexA's Avatar
Hehe. Might be a bit tricky getting the fan off, but should be possible. The fan belt is tightened by the alternator (saw tooth and gear nut arrangement). Power steering/SLS pump also has same system. The aircon belt is tightened by the air pump saw tooth and gear. Once you have a close look at it is fairly obvious. The procedure is probably in the Bentley manual (look for M30 engine as it is similar).
AlexA is offline
Old 15th January 2007, 22:30   #9
ajinfante
ajinfante's Avatar
I decided to be lazy and have my mechanic do all three. AAA towed it there an hour ago. Shouldn't take him more than an hour, maybe, right? I figure by the time I even get the belts (my friend at Bavauto didn't even have them in stock), pay for shipping (or dealer costs and tax), scrape my knuckles around inside the engine comp't to undo everything, and put it all back together, I'd probably have spent 1/3 cost of mechanic, and the high side of 3-4 hours most likely (finding correct tools takes time, and maybe money!)
thanks!
andy
Seat Belts jimmyz2 E34 M5 Discussion 4 19th February 2006 22:55
How many rear Seat belts ??? SeeSure E39 M5 and E52 Z8 Discussion 3 3rd June 2005 23:05
Really strong belts DiscoFish Off Topic Forum 7 8th July 2004 09:43
About to be Amateur M5 Racer (Hopefully) Asking Advice on Ideas Presented In Class Anita E39 M5 and E52 Z8 Discussion 22 10th April 2003 23:32
4 point belts installed (pictures calbobba E39 M5 and E52 Z8 Discussion 25 16th February 2002 03:24
Page generated in 0.14688 seconds with 11 queries
