Old 14th January 2007, 20:20   #1
Ratty
Ratty's Avatar
Garage: 1991 E34 M5 Jet Black
Clocks steaming up
Mine seems to have developed steamed up clocks since replacing one of the dash illumination bulbs recently.....
Anyone throw any light on the problem? I clipped it all back together ok and refitting went smoothly... only happens on wet days...
It's very unsightly and needs fixing asap....
Ratty is offline
Old 15th January 2007, 03:52   #2
farrell
farrell's Avatar
Sales Feedback: (4)
Hi
Did you take the intrument binnacle out on a damp day with the car outside ?
Left the car doors open for an extended period maybe ?
If so, its likely that moisture in the air when replacing the part has condensed on the inside of the glass as cabin temp has increased after fitting.
I would either run the cabin heater on full with the floor & feet vent slider shut for a good 20 mins with the car static.
Or you could get a hair drier on on the clear plastic facsia of the binnacle & evaporate the moisture.
The alternative is an obvious one requiring dis-assembly..in a garage with the doors shut ideally.
Cheers
Farrell
farrell is offline
Old 15th January 2007, 20:44   #3
Ratty
Ratty's Avatar
I think that must be the case... I think I'll take the clocks out again and warm the air up with a hair dryer before sealing it again..
Must've been just a bit damp..I certainly don't work on it when it's raining
Thanks Farrell
Ratty is offline
fan whirring behind clocks gavinp E34 M5 Discussion 1 6th June 2006 00:51
** LONDON MEET TODAY ** (n.b. clocks have changed) Ashok Arora E39 M5 and E52 Z8 Discussion 0 31st October 2004 09:45
E30 Alpina clocks nazor ALPINABoard.com | BMW Alpina Discussion 5 13th June 2004 12:58
Page generated in 0.08204 seconds with 11 queries
