Old 12th January 2007, 17:28   #1
kenanov
Garage: 92 M5 black/black 290k km, 92 525i 90k km, 94 325i convertible
topping up a steering fluid leak
My 92 3.6 M5 is leaking steering fluid from the rear shocks and seems to be leaking more steering fluid from around the engine. I am guessing thats where the pump is and its leaking from the pump. I am selling the car tommorow and the buyer will be driving it across ontario, canada from ottawa to toronto. Thats about 500Km. I dont want him to have any problems so I am wondering what kind of steering fluid do I need and where do I top it up? Also wondering if there is a warning from the computer when the level gets too low.
K
kenanov is offline
Old 12th January 2007, 18:09   #2
DookSD
DookSD's Avatar
Garage: e34 M5 Silver
it's called Pentosin.
1991 E34 M5 Silver
DookSD is offline
Old 12th January 2007, 18:10   #3
DookSD
DookSD's Avatar
Does your next owner know that SLS repairs are a little costly?
1991 E34 M5 Silver
DookSD is offline
Old 12th January 2007, 18:16   #4
kenanov
yes he does know. it costs 1200 $US for the sls and about 3 hours labour. or you can revamp the whole thing for aftermarket that will cost about the same but with new springs/shocks all around.
kenanov is offline
Old 12th January 2007, 18:33   #5
farrell
farrell's Avatar
Sales Feedback: (4)
The exact fluid is CHF11S.
Cheers
Farrell
farrell is offline
Old 12th January 2007, 23:02   #6
dronfieldm
Garage: 1995 BMW M5 3.8 6 Speed - Avus Blue
I think you top it up from the power steering fluid reservoir as normal. The SLS seems to use the same system.
I am sure other members will correct if I'm wrong. My 3.8 seems to work that way.....
Mark
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline
Old 12th January 2007, 23:41   #7
Sebring NL
Sebring NL's Avatar
Dronfield M
The SLS system is not on the 3.8.
Kenanov
Pentosin knows two types, the one you need is written on the cap.
If I was you,I wouldn't be (sending someone) driving out with a broken / leaking SLS hose, as they can easily blow. HAd that on mine. Risk is that you damage the PAS housing or more, and the pentosin will cause quite a mess on the chassis.
Wout
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
Old 13th January 2007, 13:13   #8
Mmm-Five
Originally Posted by Sebring NL
Dronfield M
Wout
So why did I neet to get my leaking SLS valve on my 3.8 replaced then
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Old 13th January 2007, 22:58   #9
///Mster
///Mster's Avatar
Garage: E34 3.8 M5
The 3.6 comes with SLS. The rears use the power steering system to supply the fluid and are electronically adjustable.
The 3.8 comes with EDC. The fronts are self contained units (not connected to the power steering) but have electronic valve adjustment. The rears are like SLS in that they use the power steering system to supply the fluid and are electronically adjustable.
The rear dampers on the EDC are therefore similar to the SLS system.
///Mster is offline
Old 14th January 2007, 00:32   #10
farrell
farrell's Avatar
Sales Feedback: (4)
The sls system IS fitted on the 3.8.
The sls valve sits above the differential with the ride height adjustment torsion arm attaching to the rear anti-roll bar.
CHF11S is the recommended hydraulic fluid as it supports Pas & SLS (3.6) plus EDC 3.8
This is critical to maintaining the integrity of the self levelling seals.
Its the same spec that Citroen use when supporting the PAS & self levelling spheres of the Hydropneumatic suspension from a common reservoir.
Farrell
farrell is offline
Power Steering Fluid on my E39 kirbanana E39 M5 and E52 Z8 Discussion 10 30th October 2006 10:05
12k Miles and Steering Fluid Leak Crabbit E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 6 11th August 2006 13:49
Possible power steering leak. plisken E34 M5 Discussion 3 19th August 2004 20:06
Power steering / rear shocks fluid icM5er E34 M5 Discussion 2 1st August 2004 20:29
power steering fluid 64lusso E34 M5 Discussion 9 21st January 2004 14:01
Page generated in 0.20698 seconds with 11 queries
