Old 12th January 2007, 10:14   #1
vadas1
vadas1's Avatar
Garage: 1994 m5 / diamond black
Low speed brake shimmy
Guys,
Recently I've noticed a slight bit of brake shimmy and an occasional gentle pull to the left when I brake moderately from says 30mph. High speed braking doesn't produce this until the speed drops to say 20mph when this will happen again. To be truthful it is probably worse below 10mph.
The suspension and suspension geometry were all checked out about a year ago and a couple of bushes renewed. Similiar for the brakes.
I've never been happy with the front tyres ( Continental Sports Contact 2 ) and still get the occasional shudder at 55mph especially when its cold. The tyre man says they are OK. When its time to change it will be PS2's.
Any ideas about the low speed brake shimmy?
ralph (vadas1)
* If it ain't broke fix it till it is *
vadas1 is offline
Old 12th January 2007, 10:35   #2
davidoli
Hi Ralph ,
It could be anything but , if I had to have a punt , I'd suggest having the control arms checked .......upper being the prime candidate .
A quick trip to a decent specialist .....1/2 an hour's labour and you should have a definite answer !
In the interim , you could always stick some Old Skool Electro on your stereo and practise your dance moves as you brake for tight corners !
Good luck .......D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 12th January 2007, 11:25   #3
farrell
farrell's Avatar
Sales Feedback: (4)
Could be bushes.
Could be partly sticking brake caliper piston/ s.
Inspect like the fellas say.
Cheers
Farrell
farrell is offline
Old 13th January 2007, 05:34   #4
GDA
GDA's Avatar
Garage: 1995 M5 Cosmosschwarz
^ Inspect is the way to verify and I'd guess worn tie rod or worn ball joint on the left side center link giving the play you sense as a wobble.
GDA
1995 M5
GDA is offline
Old 13th January 2007, 11:00   #5
vadas1
vadas1's Avatar
Originally Posted by davidoli
Hi Ralph ,
Good luck .......D
Thanks for the tip David. It's getting booked in.
Oh, by the way, if I let some air out of my R rear tire do you think that would improve the bass?
ralph (vadas1)
vadas1 is offline
Old 13th January 2007, 11:01   #6
vadas1
vadas1's Avatar
Thanks for the help guys. Getting the beast to the garage for a quick look.
ralph (vadas1)
vadas1 is offline
Dinan/Brembo Brake System NOW available howler E39 M5 and E52 Z8 Discussion 67 21st January 2009 08:26
World blind speed record attempt at 200 mph in E60 M5 beckhammania23 E60 M5 and E61 M5 Touring Discussion 29 14th October 2008 15:42
2007 6 speed manual vs SMG in the e60 vs e39? Bagger E39 M5 and E52 Z8 Discussion 21 3rd September 2006 08:31
Low speed tremor roofer E39 M5 and E52 Z8 Discussion 5 28th August 2006 10:24
From the Sunday Times Driving section...( long ) JJJ E39 M5 and E52 Z8 Discussion 13 12th July 2003 01:08
Page generated in 0.12073 seconds with 11 queries
