Originally Posted by SteveT
many thanks for reply. those long white screws are very stiff and feel like they might break if turned or does the out side screw turn which is very stiff to, cheers S
SteveT
You are right about the fragility of the adjusting rods.
They rarely get touched & sited as they are, they see engine heat, external cold & moisture.
Personally, I would get the car undercover, heat the adjustment rods up with a hair drier & get some breakfree or similar on the rod threads.
You may even be better taking the grill off to get the parts free.
If the rods break, you will have to do this anyway.
Agree with Davids comments if the adjustment is being undertaken to pass a test.
Cheers
Farrell
