Hi
Has your engine got an aftermarket eprom fitted ?
If its a stock 3.6, it should survive ok with the fuel you are using (94)though it was mapped for 95 octane fuel ideally.
I would not run the low octance fuel (89-91)
Unless the engine management has been mapped to run high octane fuel(97 & above) , you will get zero benefit from using it.
The spark will require advancing & you certainly will not gain power.
Good maintenance of fuel & spark related parts makes these cars run smooth.
The std 3.6 benefits from regular rotor (24,000 miles) ,ignition wires (every 60,000 miles or 5 yrs) & plug changes(10,000)
Change the fuel filter every 2 yrs or 24k miles etc.
Cheers
Farrell
