Old 9th January 2007, 02:36   #1
PRAXXUS
PRAXXUS's Avatar
Garage: 91' ///M5 e34 - White
Feedback on coolant flush techniques?
It's that time of year to prep for changing fluids. Specifically coolant system (antifreeze). What is your thoughts on doing it the traditional way, use drain plug on rad and on engine block near cylinder #6, and then fill with fresh fluid; http://www.bmwe34.net/E34main/Mainte...eplacement.htm
what most of the garages want to do is hook up some sort of coolant flush system, and "push" the old coolant out while replacing with the fresh coolant.
Should I stick to the traditional way or can I use the newer process most mechanics want to use??
Are there any pros/cons?
BTW, it has been recommend to use ONLY BMW coolant fluid, as the others are not as good - opinions?
TIA
PRAXXUS is offline
Old 9th January 2007, 11:10   #2
farrell
farrell's Avatar
Sales Feedback: (4)
Hi
Changing the coolant every two yrs or 36,000 miles is a smart move.
Conventional coolant change is all that is required...unless the car in question has cloudy deposits in the coolant.
First point is to use distilled water.
1. Tap water is bad for coolant systems due to the lime scale & Aluminium /
magnesium hydroxide traces sometimes present.
The presence of organic / inorganic mineral accelerates furring of the
coolant system actually reduces main & auxilliary water pump bearing life.
2. With distilled water, the absolute boiling point of the coolant is more stable
with the above removed.
If your existing coolant is cloudy, I would replace coolant & run the engine to get the coolant up to to temp ensuring no air leaks, then drop the coolant again.
Replace with new 50/50 distilled water & coolant that meets the BMW recommended spec.
You dont have to use BMW coolant unless of course, you like setting fire to $$$
I hope this helps.
Farrell
farrell is offline
Old 9th January 2007, 13:49   #3
dronfieldm
Garage: 1995 BMW M5 3.8 6 Speed - Avus Blue
I watched a BMW Technician do mine a couple of years ago. From what I could tell, he took the filler cap off, undid (slightly) the drain plug on the radiator, and ran the engine at idle, constantly topping up the tank with new coolant until it came out the radiator drain..........
Obviously he could have done other bits I didn't see, like uncrewing other bleed valves etc, but thats essentially what he did.
No trouble since...........
Mark
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline
Old 9th January 2007, 13:51   #4
davidoli
Originally Posted by farrell
David
The original thread starter title was in "CAPS"
Farrell
Cheers Faz........I looked at it after the request .....then looked at the one next to it .....with RATTLE RATTLE in the title and wondered what the hell was going on !
Hope you are well.....D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 9th January 2007, 14:35   #5
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
If the system has been properly maintaine d a routine Biannual drain and fill should be good enough. If the system has had problems and continuosly topped with tap water then a power flush with a descaler would remove some build up that occurred. Most owners of these cars are aware of the coolant system importance and also tend to keep things up to snuff so as Farrel stated you could determine the benefit by simply looking at what you remove.
unesential is offline
Old 9th January 2007, 23:57   #6
PRAXXUS
PRAXXUS's Avatar
My concern, is how the coolant is removed from the engine. There is of course the traditional method (using drain plugs), but most garages now use a method whereby they connect a machine (some sort of T-connector) and "push" out the old and replace with new coolant at the same time. My concern is how this machine does it, and how effective is it and "flushing" the system. Should I focus on using a garage that will drain and or flush the traditional way, or is it safe to use the new system.
Also re: CAPS, I apologies. I was under the assumption that it is an acceptable practice in Title.
PRAXXUS is offline
91 3.6 M5 Coolant system retains pressure when cold HCStearn E34 M5 Discussion 6 3rd October 2006 19:12
Coolant Missing GSM5er E28 M5 Discussion 4 19th October 2005 18:30
M5 Coolant Flush Schedule chunpng E39 M5 and E52 Z8 Discussion 28 12th June 2004 04:30
What's up w/ my coolant expansion tank? Gop-Dogg E34 M5 Discussion 2 25th January 2004 22:59
Does everyone has add air pressure valve on top of their coolant tank karlcchen E34 M5 Discussion 4 27th December 2001 00:33
Page generated in 0.11889 seconds with 11 queries
