Old 29th December 2006, 23:47   #1
BURTON
BURTON's Avatar
Garage: E34 M5 Black/Grey
Send a message via MSN to BURTON
Subwoofer install - E34M5
Just wondering what people have and how they have the install.
Remember you can't race your house, you can sleep in your car!
ÜberBarge.co.uk
BURTON is offline
Old 30th December 2006, 00:23   #2
Mmm-Five
Something like this?
If I was doing it again I'd get a custom enclosure which ported the bass through the ski-hatch.
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Old 30th December 2006, 01:14   #3
BURTON
BURTON's Avatar
Yes I am thinking of using the ski hatch.
ÜberBarge.co.uk
BURTON is offline
Old 30th December 2006, 03:08   #4
davidoli
Bloody hell Tony , no wonder your suspension gave up on you , lugging that lot around !
I personally never have a stereo on in the M5 , as i prefer to listen to that lovely engine roar !
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 30th December 2006, 03:47   #5
DrSakke
DrSakke's Avatar
Hi!
The previous owner had installed a stereo with a subwoofer built in the spare tyre(the tyre is there but turned upside-down and the speaker casing is in the center of the wheel) This works pretty well, but of course my car is the Estate.... Maybe not so suited for a saloon.
The amp is installed behind the left hand side side compartment in the boot, totally invisible...
Sakke
DrSakke is offline
Old 30th December 2006, 11:08   #6
BURTON
BURTON's Avatar
Originally Posted by DrSakke
Hi!
Sakke
That is something I am after... Nice and neat and out of the way..
I am thinking of one of these Active Sub's from Infinity 10" in a little enclosure with self powered easy to remove etc, but not sure on what sort of sound it would give being a sealed boot.
ÜberBarge.co.uk
BURTON is offline
Old 30th December 2006, 18:42   #7
Simonal
Simonal's Avatar
Garage: Alpina B10 V8s Touring
I have a similar set-up with the sub in self-contained tub under the rear floor. I purchased another boot floor from a breakers and the stereo fitters drilled out a speaker sized hole the fitted a heavy duty speaker grille so that the boot floor can still be used!. Then they covered the whole section in acoustic cloth which almost matches the standard grey boot floor. Thus an invisible install with the amp hidden.
I think the main problem would be getting the sound back into the cabin as it is a sealed box. The ski-hatch is the best option other than creating an alternative parcel shelf and porting that to allow more bass into the cabin!.
When I had the E30 M3 convertible which has an even more accute problem due to the extra strength of the bulkheads, and as I wanted to cause no damage but get the best sound possible. I had a custom box built which fitted in the boot and for some reason provided bass in the cabin and nowhere else! even with the hood down the passengers could hear everything but when you were outside the car the sound could hardly be heard.
In addition to fitting a sub in the boot also look at uprating the standard speakers to better versions as this can help bring the sound into the car and also reduce the amount or reliance on the sub. As the the sub is a non-directional speaker it can be sited almost anywhere while the other speakers producing the higher frequencies must be sited more carefully.
Simonal is offline
Old 30th December 2006, 18:56   #8
jimmyz2
Banned
Garage: 1995 540i 4.4L supercharged
I like tight,clean bass.So I went with a 12" sub in sealed enclosure firing directly into the ski hole.I use a somewhat light subwoofer-14lbs and a very light amp(Alpine's new PDX) at only 5lbs.To me the extra weight is worth it.
jimmyz2 is offline
Old 30th December 2006, 18:59   #9
London Mike
London Mike's Avatar
Garage: 1995 E34 V8 M5 Arctic Silver
I also use an Alpine 12" sub in an enclosure, but mine faces into the boot space, not towards the ski flap. In my car it gives a much tighter deeper sound positioned like that
M5·0 VEE
London Mike is offline
Old 30th December 2006, 19:27   #10
Cor-Jan
Cor-Jan's Avatar
Garage: alpina b10 bi-turbo DAYTONA-VIOLET
I'v i nice kenwood stereo with a vega sub wich fills half the trunk.Adjustable bass knob next to the boost control.Nothing better then a high speed run with the right music.............LOUD
Cor-Jan is offline
'00-'02 M5 Sirius Install Tips ///M_Addict E39 M5 and E52 Z8 Discussion 4 5th May 2009 02:54
BSW Subwoofer System Clearance! Halston Pitman For Sale or Wanted 10 10th October 2006 22:05
BSW subwoofer install done really wrong...help please.... 911/M5 E39 M5 and E52 Z8 Discussion 8 28th March 2006 10:46
Review and Comments on M Audio enhanced bass subwoofer install mofo_knows E39 M5 and E52 Z8 Discussion 16 17th July 2002 03:09
Page generated in 0.17725 seconds with 11 queries
